Sponsored by: DashLynx
Wheel Size Question
Old 01-12-2003, 02:41 PM
HoldTheFawkOn's Avatar
Default Wheel Size Question
Gents,
I have some questions. Can I run 18"x10" wheels (with the correct offset of 56mm) on my '94' Z-28 and also use the Eibach Pro Kit springs? Will this combination work, or should I be looking at 17" rims with this spring kit? Also, what tire size would I run on the 18"x10" rims? How much clearance would there be between the top of the tire and the fenderwell with 18" rims, the spring kit, and low profile tires?
Thanks in advance for your help. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
Old 01-12-2003, 04:32 PM
Xsta Z 28's Avatar
Default Re: Wheel Size Question
You'd probably prefer an offset of 50 mm or a little less. As for in conjunction with lowering it you should be fine. Although a 18" x 10" for the front is pretty wide.
Quick Reply: Wheel Size Question
