Sponsored by: DashLynx
Where did everyone relocate their ground wires to?
Old 01-12-2003, 09:58 PM
quickWS6's Avatar
Default Where did everyone relocate their ground wires to?
I want to relocate the grounds in my T/A. Does anyone have pics showing where they relocated them to? Or maybe you can give me some good instructions?
Old 01-13-2003, 12:09 AM
Poltergeist's Avatar
Default Re: Where did everyone relocate their ground wires to?
Not an easy thing to describe but I'll try. Plus I have a picture!
The 2 large grounds on the wheelwells I relocated to the frames. Down and toward the middle of the car. I drilled a hole and used self tapping screws from there. Also where the lug would touch I used my dremel to remove the paint so I would have good connection.
The 2 small gounds on the radialtor support I move straight down. There are some small bolts already there that you can remove and use for the grounds. Once again I removed the paint at the contact area for good connection.
I tried in the picture below to show approximately where the grounds were relocated to (red arrows). Unfortunatly I have no close up pictures of where they were relocated to.
<img src="http://home.ix.netcom.com/~rob.hagg/tempimage/Engine_Bay_grounds.jpg" alt=" - " />
Old 01-13-2003, 08:49 AM
Xsta Z 28's Avatar
Check the pics in my signature. There is an Album called "Operation Hide It!" There are four pics all the way at the bottom of the album. Hope that helps.
Old 01-13-2003, 04:22 PM
1bad2k2ta's Avatar
Do either of you guys have a step by step write up.
Sometimes a thousand words are worth one picture. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Thanks
Old 01-13-2003, 11:04 PM
quickWS6's Avatar
That really helps a lot. Thanks guys!
