Sponsored by: DashLynx
Are 4th Gen F-Body Seats Interchangeable??
Old 12-01-2010, 11:19 AM
pboxfun's Avatar
Exclamation Are 4th Gen F-Body Seats Interchangeable??
I was wondering if all 4th gen f-body seats are interchangeable? Can you put seats from a ls1 Trans Am in to a LT1 Camaro? If not what do I need to do to get them to fit?
Thanks
Old 12-01-2010, 11:31 AM
nimrod.sixty9's Avatar
Yep! 1982 ~ 2002 Birds and Camaros
Rears (bottom) on the thirdgens are a little longer so they take some convincing to get them to 'shove' in there. In your case, you'll have no problems.
Old 12-01-2010, 11:34 AM
pboxfun's Avatar
Are the electronics to power the seats the same as well??
Old 12-01-2010, 11:36 AM
Not sure if the connectors are the same. But all you need is 12v power. So if the connector is not the same, just splice, solder, secure...
Old 12-01-2010, 02:54 PM
teamfbody's Avatar
Yes they are don't really know bout the electrics but 93-02 Camaros & Trans Am seats both right up,in fact my brother has a 95 Camaro Z28 with seats from a 98 T/A
Old 12-01-2010, 03:11 PM
pboxfun's Avatar
Ok good just making sure. So only thing im unsure of are the connectors.
Old 12-01-2010, 09:24 PM
BandDirector Blk98ZM6's Avatar
I've got '99 Firebird seats in my '98 Z28 and the driver side power connector is the same and my power seat operates as it should. The only thing that you might have an issue with is the Firebird seats that have the adjustable power lumbar supports...there's an additional harness and/or connector that's needed to make that part of the seat work in Camaro's.
Old 12-01-2010, 10:03 PM
pboxfun's Avatar
If the seat has lumbar support does that mean the passenger seat is powered as well??
Old 12-02-2010, 10:44 AM
sweetbmxrider's Avatar
the passenger seat has the compressor to inflate both seats' supports. the driver seat is the only seat that has a power motor to adjust the bottom. all of the backrests are manual. there is a jumper harness that goes from the driver seat to the passenger seat. it contains electrical and air hose connections. the power lead for the seat is under the driver seat, sometimes tucked under the carpet. its an orange and black 2 wire gig that plugs right into any 4th gen seat, 3rd i don't know.
Old 12-02-2010, 11:07 AM
pboxfun's Avatar
Did all leather Trans AM LS1 seats come with this??
Quick Reply: Are 4th Gen F-Body Seats Interchangeable??
