Sponsored by: DashLynx
Lowering the Back
Old 01-29-2003, 11:37 AM
10 Second Fun Car
jlrz28's Avatar
Default Lowering the Back
Looking to drop my 2000 Z28 in the back. What does everybody use brandwise and is there anything wrong with it, Ive heard that it can mess up the pinion angle? Is that true? I just want to basically level the car out.
Thanks
Old 01-30-2003, 12:16 AM
Down's Avatar
Default Re: Lowering the Back
im using the eibach prokit w/bilsteins and its great. my pinion angle is not messed up cause i have a TQ Arm frm BMR so i can adjust it hope that helps. it just depends how much you want to lower the car mine is about a 1.8 drop hope that helps.
Old 01-30-2003, 12:53 AM
ratio411's Avatar
If you just want to drop the rear of the car and level it up a bit... Alot of folks take out the rear spring spacer and then thread a short piece of rubber hose on the top of the spring for insulation. This is good for a little over .5" drop in the rear from what I hear.
Good luck
Dave
