how wide can I go
how wide can I go
I was wondering if any of you guys know how wide you can go on the front and rear of a 4th gen. camaro before the tires will rub. I am looking to go larger in the rear than in the front. And also what the back spacing would be? On 17" wheels
<small>[ February 02, 2003, 03:19 PM: Message edited by: lethel1 ]</small>
Re: how wide can I go
50 mm offset front and rear, maybe even a little less.
Rubbing? Well depends. Is your car lowered? A 10 inch wide wheel and a 295 series tire is probably the max you can go WITHOUT MODIFICATIONS and NO rubbing.
You can run a 11" wide wheel with 315's but you will need to do minot mods, in the back.
Do a search and you'll see lots of wheel tire combos.
Friend of mine has 335/30/18's on the back of his 96 TA and it's lowered with Sportlines. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> Anything will fit with a little work. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
