Sponsored by: DashLynx
Fixing a trained mechanics work!!
Old 03-15-2011, 01:11 AM
TheZDeWolfe's Avatar
Default Fixing a trained mechanics work!!
so i was took off the door panels of my 99 z28 vert. last night. only to find out the guy i bought it from wasnt a mechanic at all. he should have took up golf instead of work on f bodys, but heres the deal. he replaced the window motor, drilled out the rivets like you should. lol then when the window goes up and down this WHOLE assembly moves. he used screws to hold the motor intact. my whole entire assemble moves probably a quarter inch. i got this on video. If you want to see this creation send me your email and i will share this with you! lol Anyone possible know how to fix this mess. and also the window is sorta falling off the track a bit cause of it? Any help would be awesome!
Old 03-15-2011, 02:51 AM
Pitbull329's Avatar
load up on youtube lol!
Old 03-15-2011, 03:03 AM
95GreenZ28's Avatar
Def have to see that to help you. I have always used screws to replace the rivets. I used lock washers on the back side though
Old 03-15-2011, 05:59 AM
99'CajunFirehawk157's Avatar
So why is this in the appearance section? Just asking...
Old 03-15-2011, 07:22 AM
dragonZ28's Avatar
Yep,
I have done that myself many times.
Lock washers, lock nuts, and your good.
It sounds like the screws have simply loosened on you. Continuing to use the motor like that could wallow out/deform your screw holes though.
Simply take the door panel off, and retighten. But make sure the hardware will not come loose again. Just use the right stuff. If you want to really make sure, loctite the threads.
Or go by yourself the equipment you need to put the large rivets in.
Thanks, Roger
Old 03-15-2011, 07:35 AM
SparkyJJO's Avatar
After I went through the whole ordeal of removing the rivets, screwing around with pulling out the daggone regulator, and having to use nuts/bolts to reattach, and realign everything, NEVER AGAIN. From here on out I take the shortcut, drill a few small holes in the fiberglass, then take the motor off the regulator and replace without messing with the regulator unit itself. MUCH easier.
Old 03-15-2011, 10:21 AM
Black94Z28's Avatar
I have a rivit gun you can borrow. Not sure how close you are to the WI/IL border though...
Old 03-15-2011, 10:24 AM
strikeone's Avatar
Amen to what dragonZ28 said, I did the same exact thing and haven't had a problem for almost 2 years.
Old 03-15-2011, 12:25 PM
94T/A5.7LT1's Avatar
Did my window motor the same way and when I got to do te passenger side I will do it the exact same way also. If the fiberglass holes on the door are not ovaled out just re tighten with locktite or locking washer and nuts.
Old 03-19-2011, 03:00 AM
Haha okay. I thought id give you boys some entertainment! i up loaded this vid of how cool this is! http://www.youtube.com/watch?v=Y5e1tW_j_ZU
Thanks for all the help. im concerned the holes are all deformed too much. See what you think!?
Old 03-19-2011, 03:02 AM
Oh BTW sorry i may have miscatorgorized this. i guess i seen interior and figured i would run it in here. my bad.
Old 03-19-2011, 11:23 AM
LilJayV10's Avatar
If you use rivets make sure you use low tension rivets. Whoever replaced mine used standard rivets which cracked the fiberglass. My door motor moves back and forth too.
Old 03-19-2011, 12:33 PM
Ghostintheshell's Avatar
golf is a very hard sport....
Old 03-19-2011, 02:23 PM
TransAm619's Avatar
Oh my god. Im having the exact same issue as the op. I put new bolts and locknuts which worked for about a week and it has just gone to **** again. Any ideas guys??
Old 03-19-2011, 05:08 PM
LilJayV10's Avatar
On fix I saw was to make a metal plate the same shape as the mounting holes. I think it's recessed back a little bit. With the new metal you are actually able tighten it down against something instead of the fiberglass giving way.
Old 03-19-2011, 06:29 PM
mushroom281's Avatar
Does anyone have the link to the website that shows you how to adjust every bolt on the window and regulator for an f body I'm sure it would come in handy for the op. Someone posted it a while back and is was very informative. My laptop crashed and I lost the link
Old 03-19-2011, 07:21 PM
luna123black's Avatar
I had the same problem the holes were screwed up in the door. I made a metal plate and then used epoxy to stick it on the door. Window goes up and seals much tighter at the top now.
Old 03-20-2011, 01:07 AM
lol! okay! glad im not the only guy stuck with this sweet ordeal! thanks everyone for the advice. NE pics by chance of this metal plate. it would just help me get a better idea of this. If anyone finds that link i would appriciate it! Just trying to fix all these lil issues in this car to make it show quality in my eyes lol
Old 03-20-2011, 01:25 AM
TransAm619's Avatar
^pics ?
Im attempting this repair tomorrow
Old 03-20-2011, 11:40 PM
yeah if you could take some let me know. just to give me a idea of this metal plate im just worried about the exact location of where the holes should be cause i dont wanna mis align everything.
Quick Reply: Fixing a trained mechanics work!!
