Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro 1990 to 2002 How to Replace Parking Lights<br>Step by step instructions for do-it-yourself repairs.
Official 4th Gen F-Body Light Bulb List
#61
I feel ridiculous asking this, but are there not supposed to be lights in the recesses of the front bumper below the turn signals? My car came with some cheesy looking and poorly wired LEDs there, and I always assumed they had replaced some stock lights.
#68
Bulb list is wrong, dome light is 561 halogen/44mm rigid loop but map lights are 214-2 halogen/42mm festoon. What I get for trusting a post without removing the mirror and checking myself first, funny Sylvania was right though.
#69
I got the 921's to replace the map lights in my 2002 Camaro, they ended up melting the covers and the housing before I caught it and removed them. I'm going to try replacing them with LED's now.
#71
It should be 194 and not 921 for '01-02, they have the same base but the average 194 is about 4W and a 921 about 18W so that's why they melted the mirror.
On the mirror lights I went with 42mm festoon ended LEDs and mine is a '96 Formula. I originally had 44mm rigid loop LEDs for the dome light but I ended up taking two of the 42mm festoon LEDs I bought and removed the contact caps and soldered them in parallel and made some loop ends, that way I have one board towards the passenger compartment and one towards the cargo area so it does a good job of matching halogen's light coverage.
#76
Yup so i.e. you're looking for a 194 just go to your favourite shopping place and search "194 LED *insert desired colour here*" Though LEDs are the proverbial minefield and researching thoroughly before buying pays dividends.
#77
Copy & Paste Moderator
#78
Does anyone have a DIRECT reference for the LED replacement for the license plate bulb. I followed the suggestion from Amazon and it did not fit. Luckily the bulbs fit in the glove box, so they did not go to waste.
I would very much like to replace the license plate bulb and the backup lights. I don't want to muck around with the brake/turn signal lamps in the rear. The DRL and front turn signals are another issue because of the heat generation.
Any tips? TIA.
Any tips? TIA.
#79
Any tips? TIA.
Any tips? TIA.
For the reverse lights I am using the XP80's from diode dynamics.
This is what I am using in my 02 SS.
#80
Thanks
Thanks for the response. I tried another 194 replacement -- didn't fit. So I used those bulbs for the map lights. Fit fine.
I'll try to get and install the Sylvania. I got some 3057 replacements off Amazon and it's a great difference.
It's some difference now with all the interior lights and most of the exteriors replaced. The previous owner put an LED bar in the Ram Air nostrils. I don't like that they're white, so I'm going to try getting some amber plexi to mount in front of them.
