Sponsored by: DashLynx
what do you use to cut antenna?
Old 03-25-2011, 09:38 AM
dc4bill's Avatar
Default what do you use to cut antenna?
What the hell should i use?haha
Old 03-25-2011, 09:48 AM
TechCam97's Avatar
I used an angle grinder, took care of it rather quickly. Then I went up to radio shack and found a little black rubber tip and put it over the end that I cut and it looked perfectly normal.
Old 03-25-2011, 09:54 AM
MTBSully's Avatar
hedge clippers?
Tin snips would probably do the trick too
Old 03-25-2011, 10:10 AM
The Mighty Texan's Avatar
Can't you just unscrew it out? I thought you could..
Old 03-25-2011, 10:12 AM
TechCam97's Avatar
Yes, it unscrews. He's referring to trimming it down to make it less noticeable.
Old 03-25-2011, 11:14 AM
GENE510SS's Avatar
i used a dremel
Old 03-25-2011, 11:25 AM
SparkyJJO's Avatar
Originally Posted by GENE510SS
i used a dremel
Same here. Cut mine half length. Then I just touched up the end with a dab of enamel paint, looked fine.
If anyone doesn't want to cut their own but wants a half-height for cheap let me know
Old 03-25-2011, 02:19 PM
dc4bill's Avatar
So it appears none of these do any damage to the antenna ill have to give it a shot
Old 03-25-2011, 02:32 PM
Super-Bat's Avatar
Guess it's just a camaro thing.
Old 03-25-2011, 02:40 PM
Danny2tek's Avatar
yep ours become short on their own
Old 03-25-2011, 03:41 PM
Rushin's Avatar
Hacksaw, Dremel, angle grinder, bench grinder, etc. You could also be creative and take MAPP gas to it and bend it into cool shapes.
Old 03-25-2011, 03:50 PM
Vexzer's Avatar
If you cut it to the wrong length, it can drive bad frequencies into the radio and burn out the tuner. This is especially true on sunny days where solar activity can syncronize the bandwidth. If the antenna gets warm that means sunspots are affecting it -don't turn on the radio or it'll explode. If you cut it be sure to check with the FCC in case you are causing interferance.
Old 03-25-2011, 04:44 PM
ZeeSNuttS's Avatar
this is why I haven't cut mine plus you can buy a shorter one from VatoZone or O'Rilleys for like 10 or 15 dollars, plus if you cut it to short its harder to pick up radio stations
Old 03-25-2011, 04:50 PM
Captain Double Post
BOBS99SS's Avatar
Yeah but its a cheap rubber one that flaps in the wind lol
Old 03-25-2011, 05:01 PM
ZeeSNuttS's Avatar
well Mr.BOB if you have a slow car like yours it stays in one place LOL and with my oem antenna I still put it back and make it move LOL
Old 03-25-2011, 05:45 PM
95CamaroLS1's Avatar
Bite that **** off with your teeth.
Old 03-25-2011, 07:27 PM
Rushin's Avatar
I just looked it up. Article 6 Section 14 of the FCC Civilian Code says "... no automotive antenna is to be below 4 inches in length, as to cause undue interference on lower frequencies in the wavelength. Under such violation, a federal felony is imposed with a fine of no less than $700 and/or up to one (1) year in prison as appointed by a federal judge in a U.S. Circuit Court..."
Yeah, I wouldn't mess with the antenna either.
Old 03-25-2011, 07:31 PM
TechCam97's Avatar
Soooo don't cut it shorter than 4 inches. Problem solved.
Old 03-25-2011, 07:33 PM
Captain Double Post
BOBS99SS's Avatar
Lol ,I just bought 2 ls1tech stickers so Zees you better watch out ,lol
Old 03-25-2011, 07:35 PM
Rushin's Avatar
Hey, some people like them really short.
Quick Reply: what do you use to cut antenna?
