Whats the best window cleaner?????
Guys i have some spots on my windows and i just about tried everything is there anything out there that works its so aggravating please help
#0000 Steel wool with water and soap.
I've done it using ONR and steel wool. Just be sure to tape off the trip along with the body. You don't want any shavings touching the panels.
1 Post
I use invisible glass also, there was some stuff i was using that alot of dealers recommended to me, but ive found invisible glass works just as well so ive just recently switched to that and am really happy with it.
Stoner glass cleaner works great. Any of those foam glass cleaners in a can seem to work good. I've had the same results with Napas or Carquests glass cleaner. They seem to be the same stuff as Stoner. I just get whatever I can find cheapest.
1 Post
If I have to, I'll use newspaper as well and I've never noticed any streaks/scratches or what have you on mine and when it comes to windows, I go over with with a real fine comb cause to me there's nothing more annoying than noticing a streak after I put in the work for a clean window, lol. As for products, either microfibers or newspaper and I use that Rain-X Window Cleaner and it works just fine to me.
I had forgotten about Hi-Sheen. It's also a great cleaner. However the only place I ever can find it is online. It is a little more expensive than even Stoner's usually too. However, right now it is on Amazon for $16.65 for a three pack. Which isn't too bad. I think it is like $8-9 a can if you buy it individually.
~or believe it or not, straight vinegar on a paper towel will take hard water spots off of glass as well. Then clean as you normally would. I used to live in an apartment complex and had to deal with their stupid sprinklers(hard water) that seemed to water the cars more than the grass....grrrr.
