Sponsored by: DashLynx
headlamp switch bulb??
Old 03-28-2011, 11:34 AM
blackfbird98's Avatar
Default headlamp switch bulb??
is there a write up on how to replace it?
Old 03-28-2011, 10:10 PM
Fosnot's Avatar
On the subject.... Where do you get the bulb?!
I took my switch apart... and its crazy small.
You pull the plastic around the gauge cluster off, then the switch area is right there, and you take that out as a whole unit. then on top of it there is this tiny black top with a notch in it, you unscrew it then pow there is this extremely small bulb (that makes the #74 bulb you use for the rest of the back lights of gauges and door handle light look big)
I don't know where to get it, but its easy to get at in the car.
Old 03-29-2011, 02:32 PM
96blackz28's Avatar
i just ordered this actually. Its a twist-lock bulb that is 3mm. Google search "neo wedge bulb" . I got mine from china egay
Old 03-31-2011, 09:23 PM
The Guz's Avatar
You don't happen to have the link. I did see that digi key has some as well.
Old 04-01-2011, 06:33 AM
stealth355tpi's Avatar
http://www.superbrightleds.com/cgi-b...pecs%2FNEO.htm
the headlight switch bulb is a plug and play, no soldering.
Old 04-01-2011, 11:42 PM
The Guz's Avatar
I know about that one. But I'm not looking for an LED replacement.
Old 12-23-2011, 12:49 PM
01_CamaroSS_SLP's Avatar
Default NEO3-xHP LED bulb
The Guz... it is an LED replacement. I'll be buying the NEO3-xHP LED bulb from SuperBrightLEDs.com (amazing website btw!) and finish my full interior LED conversion. I will let you know how it turns out and post pics if available.
Old 12-25-2011, 11:48 PM
The Guz's Avatar
An old thread. As I stated I know it's an LED replacement that was posted in the link. I was not looking to go LED but rather a halogen replacement.
Old 12-30-2011, 11:01 PM
Swiat34's Avatar
I just had to do that on my 00 WS6 and went with the LED. I didn't even notice a difference and it'll last longer.
Quick Reply: headlamp switch bulb??
