SAp removal?:/
Old 04-05-2011, 12:38 AM
camaroboy14's Avatar
Default SAp removal?:/
HEy guys I just got back from a vacation and left my car with a friend, and his tree left a couple of sap drops on my car and winshield . I just wanted to know what will work to remove it? And where to get it at? And how much?? Thanks.....
Old 04-05-2011, 08:59 AM
TImmy_Jones's Avatar
I've always had good luck with bug and tar remover...5 bucks at any place that sells car washing/waxing supplies.
Old 04-05-2011, 10:11 AM
99monguse's Avatar
If on the windshield you can use a razor blade but make sure the glass is lubricated. Heres how I would handle it...spray the entire area around the sap on the glass with either glass cleaner or spray wax or quick detailer and lay the razor blade flate and slowly shave the sap off. Keep the glass well lubricated and it should come completely clean. Or you can try sap remover too.
Now for the painted panels...you can try sap remover or get a plastic razor blade and floow the same step as above.
Old 04-05-2011, 10:28 AM
sweetbmxrider's Avatar
Denatured (Rubbing) Alcohol
I put it on a rag and rub it into the sap. It will start to smell fresh then it will begin to disappear.
Quick Reply: SAp removal?:/
