Thoughts On 4 inch Wheelbase Stretch
I'm building a new front suspension and moving the front axle forward for better weight distribution is an option. Mechanically it would be easy, but I have no clue as to how I could rework the fenders or even if it looks good. Looks okay to me. Here is a before and after Photoshop pic. Tell me what you think.
Longer wheel base is going to be counterproductive for handling/cornering. Our turning radius is already around 40ft, that'd just add to it. The cars already run close to a 55/45 weight distribution as well.
You'd have to keep the engine in the same spot, so that'll require an extended k-member or a really interesting engine mount setup or just a full custom tubular k-member right off the bat.
Better way of achieving the balance without sacrificing turning radius/etc. is with lighter components up front and maybe move some of the ballast to the back if you don't have it all eaten up with a sound system already.
Tubular K-member and suspension components up front, relocate battery to rear or run a light weight battery up front. Fiberglass/CF hood up front, re-route front wiring harness and trim it to fit as it runs all the way around the engine bay.
^^^ x2
The big question for me is the aesthetics and how the hell I'll be able to shift the wheel well openings forward.
I like the long, low look a lot more than the boxy Mustang and new Camaro look.
