Shortening a4 shifter
I dunno! Good question. I've done it to my V6 Bird and was thinking about going real short on my Trans Am when I get around to doing it.
Edit: Maybe it has to do with the diameter of the inside plastic shaft. You might NEED to have it narrower to work with the factory shift ****. I have the B&M adapter with a Hurst t-handle to I'm sure if you go that route it shouldn't matter in the least.
