Hood Spring too strong
I got it. I removed the latch and opened the 4 prongs that hold the spring in place just enough so I could unscrew the spring 3 coils and then bent the Tabs back, installed the latch and everything is good now with the lock. ..... Now all I need to do is remove the hood hinge and slot the holes so i can lower the hood a little on the driver side. Can't get the hood to lay flat.
