Cleaning under the hood without a water hose?
I've had great results cleaning greasy engine bays by spraying them down with a hose, spraying degreaser, scrubbing with a brush and toothbrush, then rinsing down again with the hose. To dry you took out your leaf blower and then got up what was left with a towel. I'd usually then fire it up and let it run for a while so any water in the crevices would heat up and evaporate.
Anyways, I'm very hesistent to try this method on my new 1995 Fleetwood with the LT1 and optispark. Any methods you recommend on how to do this job without frying my opti? The engine compartment isn't that bad, but its a bit dirty for my standards.
Yeah definitely don't do that with an LT1. I'd suggest using s damp rag to clean it and to control just a bit of water at a time. Also cover the opti with a rag while you do it. I hear simple green works well. Using a leaf blower is also great.
