Sponsored by: DashLynx
Looking for lock-in removable door bars for Cage!
Old 08-23-2011, 08:36 PM
1999FirehawkLS1's Avatar
Default Looking for lock-in removable door bars for Cage!
In a recent magazine I thinkg Hot Rod had a section on lock in end to weld on your door bar end (not swing out or anything like it )
They slide in and had a set-screw to lock them and are track legal.
They were round same dia. as your cage.
Im trying to Find the company that makes them thx!
Old 08-23-2011, 09:28 PM
popethe5th's Avatar
billet race craft makes some, theres a few comapanys our there, be careful welding theese in there a pain because your tubing will shrink after it cools from welding dont weld both ends until its bolted in, ive had good luck adding 1/16 before welding
Old 08-23-2011, 09:29 PM
popethe5th's Avatar
oh and TIG them MIG will make it shrink 3X as much because the heat is not as concentrated
Old 08-24-2011, 01:44 AM
Awsome thx thats def what i was looking for!
Old 08-24-2011, 01:52 AM
Found another set
http://www.ballisticfabrication.com/...mp_p_1467.html
but i like the billet race craft style better
Old 08-25-2011, 06:22 PM
Diplomat's Avatar
If you know the diameter of the pipe order a cage insert kit. When it sais pair it means male and female. You need two of these per door or two per bar that needs to move. Kits run from $150-$250 billet chome molly, only thing that will NHRA allow on track. if you're looking fore comething cheeper, cut the pipe where you want it to be removable got to a steel shop and find yourself a 12 inch pipe that will fit snuggly over the cage bar. Cut in half and sleave it, put some weight rated bolts through it adn you're done!
Quick Reply: Looking for lock-in removable door bars for Cage!
