Sponsored by: DashLynx
Steam cleaning engine bay?
Old 03-08-2004, 01:16 PM
NHRASE00's Avatar
Default Steam cleaning engine bay?
Looked like a simple enough way to take care of the grime that builds up on the engine. Can anyone see any drawbacks to using steam?
Old 03-08-2004, 01:37 PM
VoodooWS6's Avatar
Just be careful, pointing the steam by the coil packs, plugs and CPU. Otherwise, Steam may be a good option. Also, watch out if the steam gets really hot. Could damage the plug wire insulation..
Old 03-08-2004, 01:41 PM
NHRASE00's Avatar
Thanks for the reply.
So if I just covered up the PCM and removed the coil packs and wires everything else should be fine?
Old 03-08-2004, 02:01 PM
VoodooWS6's Avatar
Put a plastic bag around the air cleaner, CPU, and just dont point the steamer directly towards the coil packs. I have used a hose, and did not have any problems. Just let the car run for a while, to burn off any left over water!
PS..I would use some simple green 50/50 mix with water, let that sit for 1/2 hour and steam off! It will look awesome! CD-2 also makes a great kit that you can steam off...with a shine product to apply after!!
Good Luck!
Old 03-08-2004, 04:37 PM
XtinctHawk02's Avatar
I would just use "simple green".
Quick Reply: Steam cleaning engine bay?
