Engine degreaser
Engine degreaser
Im looking for a strong degreaser to get 20 years of oil and dirt off my project car. Its all over the engine bay and under the car.
Any suggestions would be great.
Well it depends.. if your going to re-paint the parts then you can go with something REALLY strong like GUNK engine degreaser.. if you dont want to damage the finish then simple green and a soft bristle brush..
Brake cleaner works very good too but again you will probley have to repaint the block and stuff.. i could also cause "splotches" on aluminum..
Well I just rebuilt the motor and put it in. Everything is powdercoated just about. Im looking to get the grease and grime off the fender wells and some of the power steering parts. The finder wells are a plastic material. Would the Gunk stuff mess them up? I may get both and use the gunk on the rear end.
Originally Posted by Steve1969LS1
Dont use the GUNK then.. given your first post it sounded MUCH dirtier.. i doubt it would hurt the powder paint but it would kill your fresh block paint..
Simple Green and a soft brush as stated.. unless you want the chance of having to pull the motor out to repaint it
Oh don't get me wrong, if we had a contest for the dirtiest engine bay and underside of the car I would win. Wish I had the car here so I could post some pics. When I get the car home I'll post some so you can see how bad it is.
I think Ill stick to the Simple Green so I don't have to repaint the block.
