BLS 93-97 Camaro Bi-Xenon Projector Retrofit - Install Pics!
#42
Copy & Paste Moderator
Can you do the same type of pics with the camera on the same settings for the 1993-1997 FX-R retrofit and the 1998-2002 Hell retrofit? I'd like to see the comparison. So far, those matchbox projectors appear to produce a narrow beam.
Was that with Halogen or HID?
#43
When I take the final pics with the setup installed, I will be using the same camera as what was done with the other headlight shots. Below were a couple quick pics taken when the projectors first came in (all with HID lamps).
Pic below is with only one projector using the same camera.
This pic is a taken with a cell phone (yea I know...) showing a comparison from a G8 halogen projector to the matchbox unit (Matchbox is the top cutoff, bottom is the halogen G8.)
#44
Does that G8 projector have a halogen bulb in it or a HID kit? It looks as bright as that matchbox projector with HID.
Whats with the odd stray light above the cut-off. Take a look at the cut-off shield for gaps/holes that should be covered.
#47
#50
Rockstar
Any idea on the final pricing of the Full set of four?
I think the issue with the appearance lies with the dual colors. If the exterior cover lens was frosted or VHT'd it seems like it would satisfy most people. I'm not too sure how a chrome surround would be in comparison.
I'm sick of the shitty light output of stock headlights, and it's way past due for something like this to be on the market. I think the execution is perfect, and adding in an exterior lens option to give it a uniform look would seal the deal for me, if not most interested buyers. Personally I think a solid black assembly when turned off would be clean as hell, stock looking too. I'd still VHT them if an option wasn't offered though.
#52
#53
#54
Originally Posted by BLSolutions
We will be getting these installed the weekend of the 9th and then be able to post all the final info.
#57
dang, about 1.5 more weeks of suspense to go! you can pretty much write me down for a set of quads with 6k hids. the black housings will actually match with my car since i've kept the headlight pockets satin black and have a black grill. basically just waiting to confirm that these will fit right as far as gaps with the hood and bumper and the quad housings relative to each other. a smoke lens option would be interesting to see if available as well.
