Easiest access to T/A Foglight Bulbs?
I used the search and couldn't find anything? How do I access the bulbs the easiest to replace them?
TIA
TIA
'Bird Director
You'll need to pop the hood and open your headlight doors. You'll be able to see the wire and the plug that the bulb is attached to as it goes into the back of the foglight housing. Just twist the plug and pull it out. It's helpful to have small hands or find someone that has small hands. There isn't much room to turn the plug once you've squeezed your hand down in there.
shouldn't be hard, my headlights are up now, cuz the gears are bad, and they stay up till I can get the brass gears I'll try it in the a.m. I got some WHITE bulbs for it, and if I like them, I'm getting the conversion set-up and matching bulbs for the headlights SOON!
Originally Posted by XtinctHawk02
Or you can go through the bottom and undo the black covering underneath the car.
Be prepared to get your arms and hands scraped up.
Went in by the headlight motors, wish my hands and forearms were smaller for a cahnge But they're in there. Can't wait till it gets dark to see how they work. THANKS
