jittery lights
jittery lights
im not sure if this is the rights section but i have been having problems with my headlights bouncing up and down. i have replaced the pivot crank arm on one side which tightened things up a little. then i noticed where the arm connects to the headlight assembly the bushing was worn so i replaced that. could a gear cause this bouncing? i really cant tell where else things are loose. thanks
