Arrggg! Paint help!
Arrggg! Paint help!
What the hell is this?
It almost looks like some oil seeped out of the filler neck and got on top of the base coat. What can I do to fix this without repainting both valve covers?
I wouldn't wetsand with 600. Start with 1000 and see if that does the trick than you'll have to use a heavy cut polishing compound followed by a medium than fine. But it might not require the medium/fine. Maybe just medium. If you were to repaint i would strip it than use lower than 1000 grit but for wet sanding typically 1000/1500/2000
