BLS...any updates yet???
do you all have any updates on the projector headlights for the 98-02 camaros?? as many of us are waiting for updates as far as development of these lights.
Odd timing of the thread but that's not a bad thing. We ordered a few sets of the DEPO housings for retrofit since the price was hard to beat. The orders for the 93-97 Camaro have taken up a lot of our time to assure they go out as promised.
As for the 98-02 Camaro, we should have some options available by the end of the month or early March. Depending on the difficulty of the retro with the DEPO headlights, we may offer both a complete setup done by us or a DIY kit for those confident with separating the lights.
We are also messing around with the Sonar units but those aren't the most fun to open up.
The goal for both will be to use a suitable 2.5" bi-xenon projector to get the job done.
Good luck with the sonars... LoL as you said they're not the easiest to open up. I helped a friend open them up to basically whistler mod them, wow that was difficult. They use better glue than the factory!
ahhh thats good to hear bout them possibly being ready by then...
are they going to stay looking like the stock chrome housing with the projectors in there or are you all going to do the whistler mod with the projectors, srry bout all the questions, just kinda want an idea of how exactly they'll look.
We are thinking about it but depends on which housings customers will have since some are easier to work with than others. Also, I'm a bit leery having us modifying customer supplied used housings because it opens up for issues. For example, customer sends in housings, has some "wear" on them, we send it back and get a complaint that this was our fault. For something like this, we can offer a lot of options from potentially a DIY kit for cheap, modified housings, and modded housings + HID kit/harness etc.
Copy & Paste Moderator
Hopefully you offer retrofitted housings instead of the Sonars. Anyone can get the Sonar housings on ebay. Also the sonar projectors, although better than most of the ebay options, still fall short compared to a proper HID projector retrofit.
As I mentioned in a previous post, we have stock style housings on their way to retro. The Sonars we had laying around and if we get something together for them, we would not leave the stock projector in place. The Morimoto H1 would be a nice choice for either housing to keep things simple but affective.
Regarding Stock Housings...
Since there is a separate high beam, you could use a low beam projector in there instead of a bi-xenon. However, the Morimoto Mini-H1 is a good projector and easy to install. There are some threads in the Lighting FAQ where people have installed them.
https://ls1tech.com/forums/appearanc...rojectors.html
https://ls1tech.com/forums/appearanc...1-install.html
However, the ones that I can think of wouldn't be as easy to install. Well, unless you come up with some sort of bracket or jig which you seem to be good at which would make installs quicker/easier.
Regarding Aftermarket Housings...
There is a thread in the Lighting FAQ where ClownVomit modified a set of the R8-style ebay housings. He replaced their original halogen projectors with Valeo HID D2S projectors from an Audi B5 A4/S4.
https://ls1tech.com/forums/appearanc...ctor-swap.html
It was a nice improvement over the original projectors and wasn't that difficult to install.
Either Route...
Take a look at the RX projector. It has great output (better than the Valeo D2S and Morimoto Mini H1), but its also a little larger and may not fit as easily in an aftermarket housing. Its not as easy to install as the Morimoto Mini H1 projector but its not any more difficult than any other OEM HID Projector.
I'm not discrediting ClownVomit's choice in projectors at all. Its much better than the halogen projectors that those ebay housings had. I'm just pointing out other options that you may want to look at.
Either Route...
So happy to hear these are being worked on. I'll send my set. Of whistler'd stockers to be a test subject as long as I get them back I also have a set of. Those eBay halos I could send it so I would def like the option to send in a set since I have 2 now I wouldn't want 3.. Lol
Either Route...
Either Route...
We may offer a variety of choices; some requiring us to do all the work due to the difficulty, while other choices that are easier can be offered and performed by either the customer or BLS.
We have a bunch of different projectors in our shop to mess with so its a matter of spending the time and seeing what works effectively.
