question on whistler mod...
Old 02-21-2012, 10:49 AM
chadroosa's Avatar
Default question on whistler mod...
when u bake the headlights in oven do you remove rubber seal around outside first or leave it on... thanks
Old 02-21-2012, 10:52 AM
The Mighty Texan's Avatar
I left mine on and i think most people do, bracket and everything.
Old 02-21-2012, 11:30 AM
chadroosa's Avatar
Cool thanks
Old 02-21-2012, 11:48 AM
No prob! I also put mine on a cookie tray (or block or wood or something also workds) just heard a couple of horror stories and decided to do it.
Old 02-21-2012, 12:07 PM
chadroosa's Avatar
Lol ok thanks
Old 02-21-2012, 12:09 PM
__Z__'s Avatar
<<<< this guy strongly suggests a heat gun vs oven
Old 02-21-2012, 01:07 PM
chadroosa's Avatar
Easier that way or jus more controlled?
Old 02-21-2012, 01:14 PM
__Z__'s Avatar
both, if you accidentally over heat the lens, when you to go grab it you run the risk of denting it it, then youll need a new set
Old 02-21-2012, 01:31 PM
chadroosa's Avatar
Does it take a while to heat whole thing evenly
Old 02-21-2012, 01:32 PM
__Z__'s Avatar
the glue will heat quicker than the plastic will
if your going to do it in the oven, just make sure and check them frequently
Old 02-21-2012, 01:55 PM
chadroosa's Avatar
Ok ill try the heat gun first to be safe and see how it goes, what kind of paint u recomend
Old 02-21-2012, 02:21 PM
__Z__'s Avatar
ide just get some high temp engine enamel (you can get it at any car store) but then again ive never done this mod lol
i just speak from the experience of doing about 30 motorcycle headlight jobs haha
Old 02-21-2012, 02:30 PM
chadroosa's Avatar
Lol nice
Old 02-21-2012, 02:41 PM
Captain Double Post
BOBS99SS's Avatar
heat gun is not needed, put in on a cookie sheet or something and keep an eye on them, i had to leave mine in there awhile , follow a write up and dont worry about it , it is pretty easy to do, i suck at stuff like that and mine came out perfect
then you really shouldnt be saying anything at all, follow whistlers write up and your good to go,there is a list of everything you need, what kind of paint/silicone to use ect.
and remember that when you pull them out of the oven they will be pretty hot, use a oven mit so you dont burn your hand of play hot potato with a headlight, also becareful and gentle working the lens off, i used a butter knife , if its still hard to get it off put back in the oven a lil longer, and try to put the masking tape on very light , it will peel the reflective stuff off, what i did was cut out some newspaper and used as lil tape as possible,you can use alot of tape just dont press it on really hard, just get it to stick a lil,
Old 02-21-2012, 02:50 PM
^ Agreed, follow the write up and you'll be golden. Easy enough.
Old 02-21-2012, 02:54 PM
__Z__'s Avatar
ive opened up more than my fare share of lights thank you...
ide just hate to see the op go and jack up his headlights bc he isnt getting all the correct information...
ive painted the inside of motorcycle headlights, just never camaro headlights, and that is the paint i used
ide say im more than qualified to give tips on opening up headlights, these are all past customers bikes...
http://www.youtube.com/watch?v=aAvRU...2&feature=plcp
http://www.youtube.com/watch?v=H43fR...4&feature=plcp
http://www.youtube.com/watch?v=tivnw...9&feature=plcp
http://www.youtube.com/watch?v=DsJNL...7&feature=plcp
Old 02-21-2012, 05:34 PM
chadroosa's Avatar
Cool thanks for all the help...
Old 02-21-2012, 05:35 PM
UnVMySS's Avatar
LoL bob is correct though. Thats great that you've opened lits of motorcycle lights and all, but these are camaro headlights and if they are stock, are plenty easy to open and the lenses do not melt. I have whistlered around 10 sets of oem, and halos for me and my friends. The oven is the absolute easiest and there is no way to damage them if you do what bob said.
Old 02-21-2012, 05:42 PM
__Z__'s Avatar
i just know what that dammmmmmmned oven did to my tail lights
Old 02-21-2012, 05:49 PM
UnVMySS's Avatar
The tail lights on these cars are much different when exposed to heat... Unfortunately. But the head lights will be fine.
