Sponsored by: DashLynx
exterior plastics fading
Old 02-23-2012, 08:03 PM
WTR's camaro's Avatar
Default exterior plastics fading
i have a 2002 z28 camaro that sat for two year before i got it, it sat in the direct sun alot which lead to some of the exterior plastics to fade. does anyone know how i can restore them or replace them. it's starting to become very noticeable.
Old 02-23-2012, 08:17 PM
Conrad's Avatar
Back to Black will probably do the trick, try that first. Otherwise, use a heat gun (careful not to touch the plastic) and it will make it black again, then hit it with the Back to Black and you should be good.
I had some really faded trim on my old chevy truck, used a blow torch and it looked really good, then I used some off-the-shelf meguiars aerosol tire dressing (don't remember the name) and the trim looked very black after knocking down the shine from the tire dressing. Don't use a blow torch on yours though lol I toasted some of the plastic doing it
Old 02-23-2012, 08:23 PM
CamaroSS27's Avatar
^ Interesting method but I have head back to black has been really good and really bad. There are other dressing and such you can use too for lazy method lol
Old 02-23-2012, 08:46 PM
i got some major detailing come up so ill be trying this out...ill see if i can upload some pics with the results
Old 02-23-2012, 08:49 PM
Conrad's Avatar
DON'T USE A BLOW TORCH LIKE I DID
Old 02-23-2012, 08:52 PM
JUSTINSWS6's Avatar
Not to hijack thread but my trim on the bottom of my window has some like oil spots. And a few swirls can i use polishing compund on it?
Old 02-23-2012, 08:57 PM
Conrad's Avatar
Are you talking about the weatherstripping? How does the rubber have swirls? Do you mean like marks from hitting it with a rotary buffer?
Old 02-23-2012, 09:01 PM
JUSTINSWS6's Avatar
It the bottom of the door windows and the sail panel rubber on the back side of the door window. I paint correction on the paint and looks great. The rubber under the door window and the rubber part on the sail panel has swirl marks. How do i detail it?
Old 02-23-2012, 09:08 PM
egott_91's Avatar
My personal favorite is Adam's Super VRT (little goes a long way):
http://www.adamspolishes.com/p-512-a...-dressing.aspx
They also have an aerosol version:
http://www.adamspolishes.com/p-517-a...-dressing.aspx
Neither of these will restore the plastic back to original, but they will make it look better. Well, depending on how faded the plastic is...hard to tell without a picture.
Old 02-23-2012, 09:11 PM
Conrad's Avatar
My old camaro had that kind of issue with the weatherstripping, I think I used armor all but you have to knock it down cause it doesn't really soak in. Don't take my word for that though. I never touched the sail panel. It's plastic so the armor all won't do anything.
I'd ask Jeff or Junkman these questions.
Quick Reply: exterior plastics fading
