Sponsored by: DashLynx
6le seat install with brackets...help!!!
Old 03-11-2012, 05:33 PM
99zMD's Avatar
Default 6le seat install with brackets...help!!!
Nothing seems to line up right. Can anyone help me get the brackets and sliders lined up on these seats? Running out of light and this is my dd! Thanks!
Old 03-11-2012, 06:02 PM
ssteven's Avatar
Pads side is easy. att seat to brackets and install. driver side .att bracket to car then put seat on top and pop in the 3/4 inch bolts.
Old 03-11-2012, 06:12 PM
99zMD's Avatar
How about the sliders? Neithet the sopplied slider nor the stock slider line up properly.
Old 03-11-2012, 06:23 PM
Amazin1's Avatar
i had to notch my sliders and use allen head bolts. then mount sliders to seat and then bolt bracket to sliders and mount the whole assembly into the car. pain in the *** but that was the best way i found.
Old 03-11-2012, 06:24 PM
99zMD's Avatar
Stock sliders or aftermarket?
Old 03-11-2012, 06:27 PM
Amazin1's Avatar
the ones that came with the seats
99zMD's Avatar
And did the drivers side bracket look crooked in the car?
Old 03-11-2012, 06:30 PM
Amazin1's Avatar
yeah but,the seat sits straight when its mounted on it
Old 03-11-2012, 06:52 PM
ssteven's Avatar
You can wobble out the bracket holes also. test fit test fit test fit
Old 03-11-2012, 07:11 PM
6LITEREATER's Avatar
What was the name on the order (just wanted to make sure you ordered 6LE style, not basic/MRC as they will not bolt up to our brackets)?
Do you have a left and a right bracket (it is water jet cut into the bracket, one says driver one says passenger)? Just want to make sure we didn't send two of one or the other...
You should be bolting the supplied sliders to the seats, then the brackets to the sliders, then drop in...
Finally any pics? These should take 20min to bolt right in, have on every other car I've done...
Old 03-11-2012, 07:52 PM
99zMD's Avatar
Name was john everhart. They say left top and right top. The sliders dont qhite match up to the seats so im gonna try to open the holes up some and go from there.
Old 03-11-2012, 08:03 PM
ssteven's Avatar
Use lock washers also.
Old 03-11-2012, 11:59 PM
99zMD's Avatar
I didn't get any pics and I ran out of light so they aren't in. 6le, I'll shoot you an email, maybe get you on the phone tomorrow to discuss.
Old 03-12-2012, 06:17 PM
Amazin1's Avatar
that's exactly what happened with mine. i had to oblong the holes on the sliders that came with the seats to get them to match up...
Old 03-16-2012, 04:58 AM
Shamson5.7's Avatar
Can anyone add some pictures as to how it is supposed to fit together? Might make things a bit easier.
Old 03-16-2012, 01:08 PM
Shamson5.7's Avatar
I got the sliders bolted onto the seats but the brackets dont match up with the sliders now.
Old 03-16-2012, 01:31 PM
Shamson5.7's Avatar
OP did you get any pictures? Im having a helluva time with this project and currently dont have anything to oblong out the holes on the sliders or brackets.
Old 03-16-2012, 01:36 PM
silversrtman's Avatar
if you had some pics of the problem I could probably help you. I have the same seats, they went in no problems though.
Old 03-16-2012, 01:52 PM
Shamson5.7's Avatar
The 2 sliders that came with them are different as shown in one of the pictures. I could only get one set of sliders bolted up. The other seat wont line up at all. The other pictures show that I cant get the brackets lined up at all. Hopefully I have them backwards or something? I cant seem to get them to line up regardless of how which way I try.
Attached Thumbnails 6le seat install with brackets...help!!!-img_0573.jpg   6le seat install with brackets...help!!!-img_0576.jpg   6le seat install with brackets...help!!!-img_0577.jpg   6le seat install with brackets...help!!!-img_0578.jpg   6le seat install with brackets...help!!!-img_0580.jpg
Old 03-16-2012, 01:54 PM
Shamson5.7's Avatar
Sorry for the bad pictures
Quick Reply: 6le seat install with brackets...help!!!
