Painting Break Calipers...
Old 03-13-2012, 11:25 AM
00Z28 ls1's Avatar
Default Painting Break Calipers...
i drive my car daily and if its more than 4-5 hr project ill wait till the weekend but i would liketo do it the next few day while the weather is nice anyone thats done it could u help me out with how much time im going to have in it?...... any tips or pointers also would be nice
Old 03-13-2012, 12:17 PM
02gangsta/ss's Avatar
Wink
Brake
Old 03-13-2012, 12:32 PM
30thanniversaryz's Avatar
Did mine in like 20 minutes. Just masked the suspension and wheel well off, scuffed the caliper with some 320ish grit, and sprayed.
Old 03-13-2012, 02:21 PM
Pipeless416's Avatar
save it for the weekend if you're waiting till you're home from work someday. it took me probably 5 hours, but i cleaned my calipers really well. most of it was prep work. i also used the brush on paint. this is after a full year of them being painted, and it's also my daily driver. take your time and do it right. you'll thank yourself later.
Old 03-13-2012, 02:25 PM
94LT1TA6spd's Avatar
I would wait till the weekend... Cleaning is the most important part of the process IMO.
I would also recommend removing ans spraying if possible. I have painted a set with a brush set, and found the paint realy gloppy and hard to use... the spray is simple and gives a MUCH better finish.
Old 03-18-2012, 10:21 PM
jbro90's Avatar
Where can I get the camaro lettering for the calipers
Old 03-19-2012, 09:24 AM
SR_Blaze's Avatar
Link to caliber decals.
http://fourthcircledesigns.com/produ...a0753268012750
Old 03-19-2012, 10:17 AM
Formally Simplɘ Jack
BoricuaHec01's Avatar
I'm painting my calipers/brackets within the next week, can't wait. Post pics when finished OP.
Old 03-19-2012, 10:19 AM
Rise of the Phoenix's Avatar
Did you paint your's without removing the caliper? Is that possible.
Old 03-19-2012, 10:44 AM
Yes, it's possible. He used a paint brush so that's a lot easier to work with oppose to spray paint and polishing.
Old 03-19-2012, 11:41 AM
nichoLaS1's Avatar
As is the case with any paint job, its like 80% prep time and 20% application. Wait till the weekend, dont try to rush it. The smoother/cleaner you get your calipers, the happier you will be with the results. If you're spraying I recommend taking the caliper off (only 2 bolts), that way you can spray every surface evenly. Although yes technically you wont really see the inward facing side of the caliper. If you do take them off, just make sure to hang them with wire or something, so that they are not hanging by the brake line
Old 03-19-2012, 11:45 AM
Where do you guys recommend I buy the Camaro decal, Afterthoughtsauto or Maryland Speed?
Old 03-19-2012, 01:22 PM
i did remove the calipers to paint, so the entire piece is painted, not just what you can see. the brackets were also sprayed, so i obviously removed them as well.
Old 03-19-2012, 01:46 PM
nichoLaS1's Avatar
google Brent Franker.. great guy to work with
Quick Reply: Painting Break Calipers...
