Sponsored by: DashLynx
I need a bad ass degreaser to clean a rear end before install. Sugestions?
Old 03-27-2012, 06:02 PM
ANTICOP RAM AIR's Avatar
Default I need a bad *** degreaser to clean a rear end before install. Sugestions?
Im about to put a different rear end in my TA... Its pretty dirty as you can imagine. I need some serious *** degreaser/cleaner or ???? to clean it off... Ill probably sand blast it and put some coating on it that they use for them and transmissions.. (forget the name)... What would you use? The rear has nothing on it, no suspension/brakes or LCAs...
Old 03-27-2012, 06:04 PM
SupahRich's Avatar
I've always had luck with Purple Power.
Old 03-27-2012, 06:11 PM
JUSTINSWS6's Avatar
I would just san blast it. Wipe of most of the grease sand blast it. Then paint it and clear coat it.
Old 03-27-2012, 06:15 PM
Well, Im about to pull it out of the garage, spray it down with a blend of :
simple green, windex, purple power, laundry detergent, liquid soap, bleach and maybe a little fabric softener.. haha.... Im gonna get this ****** clean...
Old 03-27-2012, 06:31 PM
JUSTINSWS6's Avatar
What type of rear end is it?
Old 03-27-2012, 06:32 PM
DietCoke's Avatar
Pressure washer
Old 03-27-2012, 07:23 PM
StealthWeaponLS1's Avatar
Actually a pressure washer might be your best bet. If you put the right tip on the pressure washer gun, it will take gum off of concrete. So....grease shouldnt be a problem.
Old 03-27-2012, 07:25 PM
JUSTINSWS6's Avatar
Ya power washer would work... Take it up town in a truck if you dont have one.
Old 03-27-2012, 07:34 PM
Ive got a 1200psi electric husky pwr washer I use on my car with the foam gun... Ill probably do that after its soaked for a bit...
the rear end is a 10 bolt 3.42 from a 6speed car... I have 3.23s now but the lsd is toast and I dont have the cash for the Moser I want...
Old 03-28-2012, 12:15 AM
LilJayV10's Avatar
Purple power, work it in with a brush, let it sit for a while then hit that bitch with a power washer!
Old 03-28-2012, 12:20 AM
I took it out tonight and soaked it and hit it once with the washer.. sprayed it again and then put it back in the garage.. Ill finish tomorrow when I can see wtf Im doing... im going to sand blast it too so it looks nice and neat...
whats the name of the paint the use on these types of parts? I hear its some mean ****... cant remember the name.
Old 03-28-2012, 12:25 AM
I found it.. POR 15. does this **** come in any other color? Silver or Red maybe?....
Quick Reply: I need a bad ass degreaser to clean a rear end before install. Sugestions?
