"Reverse" lights not working.. Any1 had this problem??
Old 03-29-2012, 08:34 PM
09camarossls2's Avatar
Default "Reverse" lights not working.. Any1 had this problem??
Both reverse tail's dont work..
I check for any blown fuses on the fuse box inside and out.. and nothing
Then B 4 i bought new ones i check the current reverse bulbs on "both" sides of the tails by swaping them arround on the brake socket's.. and bulbs do function..
I check for power on the socket/wires and am NOT getting any power..
Now.. everything on the car seems to be working just fine turn signals,dome map lights,gauges,DLR, ECT..
EXCEPT for the reverse sockets/ligh bulbs
Sockets are really clean both.. even that wouldnt explain BOTH sides going out uuhhmmm....
Can it be my reverse switch by the tranny..??
I have a 99 camaro M6
Any One had this problem or any good advice..?? Thanks!
Old 03-29-2012, 09:18 PM
silver1r's Avatar
It could very well be your reverse switch on the tranny like you mentioned. It is on the right side of the tranny about in the middle, I believe. Just unplug it and use ohms meter on the switch. It should be open when not in reverse and closed when in reverse.
Old 03-29-2012, 10:27 PM
I figured.. Since it would probably be last thing to check..
Ok thanks.. Thats excatly my next step..
1st thing 2morrow morning am checking that switch..
Quick Reply: "Reverse" lights not working.. Any1 had this problem??
