Sponsored by: DashLynx
replacement seat foam
Old 04-04-2012, 06:58 AM
Beastmode89's Avatar
Default replacement seat foam
I bought an 02 ta recently and the leather seats are in excellent shape, but the driver butt foam is worn as hell. Where should I look for the replacement piece of foam? Also, how much should I pay someone to install it for me? I know nothing about upholstery.
Old 04-04-2012, 10:21 AM
sjsingle1's Avatar
there is NO current availability of front seat foam for 4th gens......someone would have to custom make it or you can scour junkyards.......i had mine redone at a upholstery shop but it crapped out after 6 months
Old 04-04-2012, 02:15 PM
whytryz28's Avatar
Get some replacement foam and glue it on the stock.
Old 04-05-2012, 06:11 AM
01ssreda4's Avatar
Get a replacement from a passenger side seat....they are identical and usually in way better condition then the driver's side.
Old 04-05-2012, 08:40 PM
RyanSws6's Avatar
I went to the junk yard and found a perfect right seat that was cloth. I took everything apart, took out the seat foam bottom and put it on my driver seat. I had found some used great seat leathers and replaced the leather too. Now everything matches and all is OE. I did the same to the left lean back too. Not very hard.
Old 04-05-2012, 09:58 PM
Ghostintheshell's Avatar
Yup. I looked to no avail.
The first company to make it will likely do well.
Quick Reply: replacement seat foam
