Sponsored by: DashLynx
How does this ride height look?
Old 04-21-2012, 09:09 PM
lees02WS6's Avatar
Default How does this ride height look?
26" in the front, 27" in the rear. I'm hesitant to lower the rear any more, I have 3" of compression travel (really less, the tire touches the outer fender before i get to frame). To get lower I'd have to run narrower tires or more negative camber.
Old 04-21-2012, 09:25 PM
stevesfbody's Avatar
Old 04-21-2012, 09:33 PM
CamaroSS27's Avatar
looks good
Old 04-21-2012, 10:39 PM
Super-Bat's Avatar
I like it. What's your set-up?
Old 04-21-2012, 10:43 PM
lees02WS6's Avatar
Koni SA's with strano springs up front, re-valved Koni DA's rear with a 288 in/lb leaf on lowering bolts.
Old 04-21-2012, 10:46 PM
94LT1TA6spd's Avatar
I think that it looks great!
Old 04-21-2012, 10:51 PM
chaman's Avatar
Looks good but it needs a bit more of a drop in the back, IMO.
Old 04-21-2012, 11:01 PM
lees02WS6's Avatar
I'm thinking that too, but that's a wheel rehoop and new tires. I could add camber, and then i'll need new tires sooner, lol.
I've thought about running nitto's also. The GS-DS3's just run so damned wide.
Old 04-21-2012, 11:12 PM
carlos64030's Avatar
You say that like it's a bad thing.
Old 04-21-2012, 11:19 PM
lees02WS6's Avatar
I've seen your car, Austin Auflick's, SHovV's car, and those wide meats are great. In this case, for me, wide isn't always better.
I can pick wide and rake, or less wide, lower and more level (without adding more work of course). I say I can add camber, but if I did that I'd probably hit the inner fender well. There's just not a lot of room to play with.
I could run Nitto 315's probably and have fewer issues.
Old 04-22-2012, 12:31 AM
The Mighty Texan's Avatar
It looks good, i like a little rake anyways, nice work!
Old 04-22-2012, 12:46 AM
dabest09's Avatar
Do the hose mod and it'll sit perfect.
Why does the position of your rear caliper so high up?
Old 04-22-2012, 02:29 AM
whytryz28's Avatar
Whats the fender lip height from the ground? Anything higher than 26" its gotta come down.
Old 04-22-2012, 02:44 AM
scj
scj's Avatar
Are you running c4 IRS?
Old 04-22-2012, 06:10 AM
lees02WS6's Avatar
Yes
Can't, see above. I can adjust the ride height by loosening, or tightening the nuts on either end of the spring though.
26" front, 27" rear
Old 04-22-2012, 06:54 AM
lees02WS6's Avatar
Close up of the rear height.
Old 04-22-2012, 10:57 AM
^^^^ I love it, but those tires need some shine!
Old 04-22-2012, 11:19 AM
chaman's Avatar
This.
Old 04-22-2012, 12:45 PM
lees02WS6's Avatar
This.
No can do, IRS. I'll lower, and raise the compression damping.
Old 04-22-2012, 12:48 PM
lees02WS6's Avatar
The whole thing needs a wash, it's been in the garage since Oct 2011, and has only been out for short test drives since Oct 2010. I have been changing the fluids though.
I literally dusted it off.
Quick Reply: How does this ride height look?
