Spoiler question??
Spoiler question??
Dont beat me up for asking this question but after reading and researching I still cannot figure this out. My 99 trans am looks like it has a formula spoiler or hatch on it? I ran the VIN # on compnine and figured out that it is a TA and it has an Rpo code of T48 spoiler? I understand that there is a possibility that a previous owner replaced the hatch on it with a non high rise formula one, but I don't know that for sure so was this car ordered with this hatch/spoiler on it or was it a replacement?
I will have to post a picture later when I get home but I am sure you get te idea.
It's definitely a TA it's a ls1 6 speed I just can't figure out if one would ever come factory like that or if someone changed the hatch and or rear bumper. That's not the best picture it's all I had on my phone. Here is the compnine report.
Vehicle: FIREBIRD 2 DR
Year: 1999
Build Date: 1999-02-16
Found 32,938 vehicles matching your year and model in our database.
RPO dum dumDescription
UA6 dum dumTHEFT DETERRENT SYSTEM ANTI-THEFT(UA6)
UB3 dum dumCLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
UK3 dum dumELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
U75 dum dumANTENNA,POWER(CHROME) PWR ANT(U75)
VM3 dum dumLABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
V73 dum dumVEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
WS9 dum dumMODEL CONVERSION FORMULA(MERCHANDISING OPTION) FORMULA(WS9)
W55 dum dumENTERTAINMENT SYSTEM OPYION E ENTERTAINMENT SYS OPT E(W55)
Y82 dum dumTRANS AM PKG BASE(MERCHANDISING OPTION) PKG,TRANS AM BASE(Y82)
Including
* dum dum28U - EXTERIOR COLOR, PRIMARY, NAVY BLUE MET (28U)
* dum dum7ZM - COMPONENT FRT RH COMPUTER SEL SUSP (7ZM) SUSP(7ZM)
* dum dum142 - TRIM COMBINATION LEATHER, LT GRAY (142)
* dum dumR9P - CONTROL SALES ITEM NO. 90
* dum dumUB3 - CLUSTER, INSTRUMENT(OIL, COOLANT TEMPERATURE, VOLTMETER, TACHOMETER, TRIP ODOMETER) GA(UB3)
* dum dumV73 - VEHICLE STATEMENT US/CANADA US/CANADA VEHICLE STATEMENT(V73)
* dum dumUK3 - ELECTRONIC SYSTEM, ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
* dum dumUA6 - THEFT DETERRENT SYSTEM ANTI THEFT(UA6)
* dum dumVM3 - LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
* dum dumWS9 - MODEL CONVERSION FORMULA(MERCHANDISING OPTION) FORMULA(WS9)
* dum dumW55 - ENTERTAINMENT SYSTEM OPYION E ENTERTAINMENT SYS OPT E(W55)
* dum dumY82 - TRANS AM PKG BASE(MERCHANDISING OPTION) PKG, TRANS AM BASE(Y82)
* dum dumU75 - ANTENNA, POWER(CHROME) PWR ANT(U75)
* dum dumMM6 - TRANSMISSION MAN 6 SPD, BORG WARNER, 85MM, 1ST 2.66, 6TH 0.50, O/D 6 SPD M/TRANS(MM6)
* dum dumQLC - TIRE, ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC)
* dum dumT78 - HEADLAMPS CONTROL DELETE T78)
* dum dumT43 - SPOILER, REAR RR SPLR(T43)
* dum dumSTE - PLANT CODE ST THERESE, PQ, GM OF CANADA ST THERESE, GM OF CANADA PLANT CODE(STE)
* dum dumR7X - CONTROL SALES ITEM NO. 48
* dum dumPA6 - WHEEL, STYLED(PAINTED) STYLED PAINTED WHL(PA6)
* dum dumNF2 - EMISSION SYSTEM, FEDERAL, TIER 1 FED EMIS SYS(NF2)
* dum dumNP5 - STEERING WHEEL, LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
* dum dumMN6 - TRANSMISSION, MANUAL 6 SPEED PROVISIONS(MERCHANDISING OPTION) 6 SPD M/TRANS PROVISIONS(MN6)
* dum dumG80 - AXLE, REAR, POSITRACTION, LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
* dum dumK43 - GENERATOR 102 AMP 102 AMP(K43)
* dum dumLS1 - ENGINE GAS, 8 CYL, 5.7L, SFI, ALUMINUM ENGINE 5.7G(LS1)
* dum dumGU6 - AXLE, REAR, 3.42 RATIO 3.42R(GU6)
* dum dumJ65 - BRAKE SYSTEM, POWER, FRONT AND REAR DISC 4 WHL DISC BRK(J65)
* dum dumFE9 - FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
* dum dumFE2 - SUSPENSION SYSTEM, RIDE AND HANDLING RIDE & HANDLING SUSP(FE2)
* dum dumDL5 - DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
* dum dumDG7 - MIRROR, OUTSIDE, RH & LH REMOTE CONTROL, ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
* dum dumC60 - AIR CONDITIONER, FRONT, MANUAL CONTROLS A/C MAN CONT(C60)
* dum dumCC1 - ROOF, HATCH, REMOVABLE PANELS, GLASS HATCH RF(CC1)
* dum dum14I - INTERIOR TRIM LT GRAY (14I)
* dum dumAQ9 - SEAT, FRONT BUCKET, DRIVER, PASSENGER, RECLINING RECL FRT BKT ST, LUXURY(AQ9)
* dum dumAU3 - LOCK, SIDE DOOR, ELECTRIC ELEC S/D LK(AU3)
* dum dumAU0 - LOCK CONTROL, REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
* dum dumAK5 - RESTRAINT SYSTEM, FRONT SEAT, INFLATABLE, DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
* dum dum1SA - PACKAGE OPTION 01 (1SA)
* dum dum6ZM - COMPONENT FRT LH COMPUTER SEL SUSP (6ZM) SUSP(6ZM)
* dum dum8TJ - COMPONENT RR LH COMPUTER SEL SUSP (8TJ) SUSP(8TJ)
* dum dum9TJ - COMPONENT RR RH COMPUTER SEL SUSP (9TJ) SUSP(9TJ)
* dum dumA31 - WINDOW, POWER OPERATED, ALL DOORS PWR WINDOWS(A31)
* dum dumAAA - Unk.
* dum dumAG1 - ADJUSTER FRT ST POWER, MULTI DIRECTIONAL, DRIVER MULTI DIRECTIONAL PWR D/SEAT ADJR(AG1)
* dum dumDE4 - SUNSHADE, REMOVABLE HATCH ROOF HATCH RF S/S(DE4)
* dum dumIL2 - TRIM, INTERIOR DESIGN (IL2)
Year: 1999
Including
* dum dumAAA - Unk.
I dont think that there was an option for spoilers, only way a T/A got that spoiler is if it was on a convertible. Could have been in an accident and replaced
Could you post up some better pics of your car
I will have to post some more pics when I can this weekend. So your thinking there isn't any way that it came this way? The rpo code Y82 trans am package base which means it is a TA so I guess I am more curious to know if there was anyway possible that it could've come stock this way? I will get some more pics up when I can. Thanks for the replys, I've read alot of threads and forums trying to get to the bottom of this. Thanks again!!
I'd say it was a trans am that got hit in the rear and they replaced all the parts with firebird parts (center filler panel, rear bumper, hatch) it does have the side GFX. what does the front look like?
If it has RPO Y82 it is a trans am though.
Guess I will have to start pricing some, I would like to put a TA bumper and hatch back on it. I will probablyl get a hood while I am at it and just have the whole car painted at once. So I guess that answers my questions someone has changed them out at some point. Since it didn't come from GM like that. Thanks for all of the input.
