my experience cutting a4 shifter
well I was attempting to cut my stock shifter, and I messed up. i was scared to cut past the point where the plastic piece changes diameter, but i did it anyway. a few hours with a tiny dremel, my adapter, a hurst t handle, and a grand prix boot, and Im satisfied!
heres before i got it how i wanted
it was about an inch higher.
Bumping this thread.
I shortened my shifter and the spring mechanism and everything was working well. As soon as I put the shift plate on however, the spring mechanism is such that I physically have to pull hard up on the shift ****. With the shift plate off, you press down on the aftermarket shift **** to shift, and then it automatically just pops up. There's nothing obstructing the spring mechanism either when the shift plate goes on.
Copy & Paste Moderator
Did you also install a leather shift boot? You might need to loosen the screws mounting the plate then. Just need it barely snug, not tight. Also, ditch the black plastic sliders if you have a leather shift boot. And make sure the shifter goes through the loop of the sliding mechanism. I didn't have a problem with button sticking down, but the mechanism made moving the shifter too stiff.
http://www.fadingarrow.com/ShiftBoot.htm
So you only used the sliding mechanism that shows what gear you are in and ditched the rest of the sliding plates? That slider doesn't have support on the non indicator side which was my concern. I tried it without the boot and had the same problem. I'll loosen the 4 screws and see if it resolves it.
