Bought a Porter Cable...Now I need pads.
Finally found a Porter Cable locally.
I tried using the supplied pad as a practice run....It works but it isn't working well enough for me.
Just wondering if the experts here could recommend some pads for me? I need something with some cut as I have BAD swirls. I've been on all the detailing sites but all the numbers and colors mean nothing to me...So please help a noob out.
A lot of people say the lake country flat pads are a lot better than the ccs pads. But if that's not cutting it grab some microfiber pads. Also, all this information should be in the "ask a professional detailer" thread.
Typical compounds you'll see recommended are Meguiars 105 and 205, Meguiars Swirl Remover 2.0, Mezerna SIP, Adams, etc. The ultimate compound is alright if you have really light defects, or want to hand polish, but there are definitely better options for machine polishing. I've used the ultimate compound before, but wasn't as impressed as I was with their higher grade compounds.
Our local autozone's started carrying Meg 105/205 recently. I used to have to go to a special supplier in town to get some.
As far as waxes, a lot of guys will recommend Blackfire Wet Diamond sealant, does wonders on black vehicles. I used Meguiars 21 synthetic paint sealant the first time I detailed my car, now I just use Meguairs Deep Crystal Carnuba wax for a fresh coat every month or two. The meguairs deep crystal is cheap, off the shelf from autozone, but it works for what I use it for.
Ask A Professional Detailer
This thread is your best friend for pretty much anything detailing related.
The 3M stuff is garbage yes....but it also is not wax.
Lake Country flat pads: Orange, white, black for correction. Red or blue for applying sealants/waxes.
Heavy cutting: meguiars MF cutting discs.
Get 5.5" pads and get the Mirka backing plate Part Number:
916SGV (the one with all the vent holes in it). Can be bought at buffdaddy.com
you would want to use something lighter in cutting power before the wax... pre wax cleaner, paint cleanser, swirl remover, etc etc
once you get real pads you will able to do a lot more
