projector flicker problem
When you mentioned you swapped ballasts and lamps, did the issue stay on the passenger side? Looks like the lamp isn't getting full power to start completely. Did you contact TRS directly?
I spoke to them and showed the video. They believe it to be a power issue. I think we went over this before but I would see if running the car and letting the battery fully charge solves the problem. The flickering going away when you unplug the driverside ballast suggests there isn't enough power to keep both lamps lit effectively.
