Sponsored by: DashLynx
How to fix cloudy carbon fiber?
Old 07-21-2012, 03:04 PM
porksoda's Avatar
Default How to fix cloudy carbon fiber?
Got a good deal on these engine covers for my Silverado. Only problem is that 2 of them are very cloudy. Would this be as easy as sanding down to the carbon fiber part without tearing it up and putting a new clear coat back down? Here is the 2 bad ones first:
This one is the only one that looks decent to me
Old 07-21-2012, 03:07 PM
__Z__'s Avatar
Wetsand/buff/wax
or sand and reclear
Old 07-21-2012, 03:09 PM
67goatman455's Avatar
dont sand down to the carbon. you will have a mess at that point. sand a little bit with 600 until the cloudiness goes away then re-clear. i would put a professional automotive clear on it from a gun so it will look good for a really long time
Old 07-21-2012, 03:12 PM
porksoda's Avatar
Yea I didn't mean sand down into the fibrous part. Just enough to clean up and clear it again. I planned on using automotive clear coat but does it need any additives for the engine bay or because it is carbon fiber? Or just regular old clear coat?
Old 07-21-2012, 03:27 PM
regular clear coat is fine sir
Old 07-21-2012, 04:35 PM
porksoda's Avatar
What grit? About 800 to take it down pretty fast?
Old 07-22-2012, 12:35 AM
no, go with 600. dont even have to go up to 800 to re-clear (well you may just in case)
Old 07-23-2012, 02:24 PM
porksoda's Avatar
I've wet sanded a little bit with 800the and doesnt seem to be working. Still looks just as cloudy. Guess i'll try to hit it longer with 600 and see if it helps.
Old 07-23-2012, 07:05 PM
if you have to go down to 400 thats fine, just be carefull. then jump to 600 then 800
Old 07-23-2012, 11:28 PM
GoFast908Z's Avatar
try polishing first.....
Don't use the cruise missile when a .45 might do the job. Least aggressive method FIRST. ALWAYS.
Old 07-24-2012, 12:38 AM
HotWhipT/A's Avatar
YES!
I have some pics for reference I've done. This was on a Ferrari Enzo
Old 07-24-2012, 01:13 AM
GoFast908Z's Avatar
^ Jealous..... do want.
Old 07-24-2012, 06:48 PM
LS1-IROC's Avatar
Your screwed...you will never get the cloudiness out. It's in the resin itself, no way to sand or polish it out. The reason it's clouded up like that is because it's an amateur CF layup.
Old 07-24-2012, 07:08 PM
highly doubt it is yellowed that deep.
Old 07-25-2012, 05:45 AM
LS1-IROC's Avatar
It's not yellowed...it's cloudy. It comes from tiny air pockets in the resin that have moisture in them that cloud up when exposed to heat...but what do I know...LOL
Old 07-26-2012, 10:06 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Exactly, your trying to level the clear and taking too much off can create issues later.
Old 07-26-2012, 06:25 PM
porksoda's Avatar
I think LS1-IROC is right. Doesn't look like this is gonna polish out. Went at it today and didn't seem like I was making any progress towards getting it clear. May just paint them and airbrush something fancy on it.
Quick Reply: How to fix cloudy carbon fiber?
