My recent subtle interior mods
Let me know what you think.
-HUmount
-Chrome vent rings
-Shortened stock shifter 3/4"
-Bird decal on gauges
next project will be wrapping my cracked-to-**** dashpad.
-HUmount
-Chrome vent rings
Thanks i was a little hesitant to get the rings because i didnt want it to look cheap and ricey but after seeing alot of pics on here i decided to try it. You never really can tell how something will look until you see it in person, im glad i got them.
Yea i used a dremel with a cut off disk. Just took off the **** and made all the same cuts as it already had just 3/4" longer, then cut off the top. 3/4" is the most i could go with the stock **** and still be able to get it into park without the **** hitting the plastic in front.
On the little flash drive thats in there you name your folders that hold music and i just named one badbirdie. You have options of what the head unit displays such as folder name, track title, artist name, etc...
Thanks for all the compliments guys
Copy & Paste Moderator
There are a few threads on this. Here are some I found searching for "cut shifter" & "shorten shifter":
https://ls1tech.com/forums/appearanc...-write-up.html
https://ls1tech.com/forums/appearanc...c-shifter.html
https://ls1tech.com/forums/appearanc...installed.html
https://ls1tech.com/forums/appearanc...-opinions.html
You wont have to worry about this, but i also cut 3/4" lower than where the slots were for the staple to hold the stock ****
thanks
