Sponsored by: DashLynx
whistler mod help
Old 07-31-2012, 09:25 PM
stangkiller2005's Avatar
Default whistler mod help
im about to do the whistler mod on my car. but i cant remember at how many degrees i need to set oven and for how long. anyone that cant point me in the right direction? thanks in advance.
Old 07-31-2012, 11:45 PM
buellxb12s's Avatar
I did two sets of headlights last week at 200 for 20 minutes.
Old 08-01-2012, 12:16 AM
TX RED's Avatar
use a heat gun much faster
Old 08-01-2012, 12:41 AM
bill12690's Avatar
Just incase you haven't started yet or whatever, it's a good idea to use black silicone when putting the lights back together. Can't remember if it says that in the write-up or not, just something to think about. I did mine around 20 min at 200 or 210 also.
Old 08-01-2012, 01:45 AM
i used clear silicone in the past. its what i bought aswell. should i return it and switch to black? the blow dryer seems like it would take a very long time... anyone else done it with a blow dryer? i dont have access to heat gun at the moment, but i know hair dyers should get hot enough. may be wrong tho.
i did it in the oven, but it was years ago. needed a refresher. thanks guys.
Old 08-01-2012, 07:45 AM
Z28Dave's Avatar
i used a heat gun i bought at home depot for like 20 bucks and it worked wonders getting them apart. i wanted to plasti dip the lights and cut away the part that covers up the reflectors but never did. but a heat gun and a putty knife got the job done for me, just try not to heat up the weather stripping like i did haha
Old 08-01-2012, 10:24 AM
sweetbmxrider's Avatar
200 degrees for 10 minutes is plenty.
Old 08-01-2012, 10:52 AM
bill12690's Avatar
I used clear also, just if you use too much or some squeezes inside the lens it may look better black instead of clear. You'll be fine with clear, just don't use way too much
Old 08-01-2012, 12:54 PM
Got it. Thanks guys. Ima probably do them today. Ill post pics when im done.
Old 08-01-2012, 08:58 PM
TX RED's Avatar
Auto zone has a heat gun for under $50
Old 08-02-2012, 03:56 AM
Finished them. Used the oven. I think 25 min would have been alittle better but got em open. Ill post a pic tomorrow. My lenses are foggy tho
Quick Reply: whistler mod help
