Sponsored by: DashLynx
took a shot with the blackbird stripes
Old 08-12-2012, 10:14 PM
joshua cobos's Avatar
Default took a shot with the blackbird stripes
got flat black blackbird stripes on the firebird a couple of days ago...still has a few tiny bubbles to work out. I loved the turn out because u can only see them at certain angles
Old 08-12-2012, 10:37 PM
dabest09's Avatar
That looks great! When you gonna swap an ls motor in there?
Old 08-12-2012, 10:41 PM
BadBirdie's Avatar
i like that last shot with the ws6 lurking in the background. stripes look good.
Old 08-12-2012, 10:50 PM
Morphine's Avatar
Agreed. Very cool choice.
Old 08-13-2012, 11:17 AM
CamaroSS27's Avatar
look really good!
Old 08-13-2012, 08:36 PM
MavrikTA's Avatar
Love Blackbird stripes! Classy man!
Old 08-13-2012, 08:38 PM
brnagn's Avatar
That looks awesome! Great job.
Old 08-13-2012, 08:42 PM
sam95transam's Avatar
damn that thing looks nasty
Old 08-13-2012, 10:08 PM
Furious1's Avatar
Looks awesome...I often wondered if I could pull off the same affect, but on white.
Old 08-13-2012, 11:07 PM
thanks for the compliments guys...i also added some drilled and slotted rotors....i will post some bics of those as well
Old 08-15-2012, 05:29 PM
Slowv696's Avatar
did the same with mine. also did the wing tips also
Old 08-17-2012, 10:11 AM
Sexy_WS6's Avatar
Looks nasty man i DIG IT!!!
Old 08-17-2012, 07:12 PM
bigbomber5's Avatar
Could you please tell me the steps you did or write up you followed. My first attempt on putting on the stripes I messed up on the first stripe... So I ordered another set and haven't touched them. I've called several local decal shops and they won't even attempt to apply my blackbird stripes.
Old 08-17-2012, 09:36 PM
91rs355's Avatar
Looks great bud, nice touch
Old 08-17-2012, 10:49 PM
yeah i hear you...i screwed up one set of stripes up already on my first attempt.....re-ordered some new ones and found out that the trick to the best way to install them is by weting the hood and decal itself before you peel it off.....after its nice and wet peel decal and position it on hood.....this is where pre-soaking the decal comes in cause once you lay it on the wet hood it will slide where ever you want it too...after you position it dry carefully with a soft rag and slowly work bubbles out....after that the sun will work out the rest of the small bubbles.......hope this helps....mine came out great!!! good luck
Old 08-17-2012, 11:14 PM
CroLs1's Avatar
Default Black Bird
Love thos stripes on these cars, this is my favorite one and im debating on doing it to mine same color.
Old 08-18-2012, 05:20 AM
bigbomber5's Avatar
Cool thanks man. Did you use a squeegee(spelling?)?
I think I'm gonna give this a shot....again lol!
Old 08-18-2012, 05:49 AM
crimson_bird's Avatar
Looks pretty good. LOVE black stripes on a black car, and you can't go wrong with the blackbird stripes! I'm thinking about doing the wingtips like slowv696 has, but I'm on the fence. not sure how it'll look with my stripes... most likely will end up trying them out though
needed: squeegee, spray bottle (water+soap), tape, marking pen, blow dryer/heat gun (not absolutely necessary, but helps)
1) cut away the bulk of the paper/plastic that contain the stripes, leaving only about 1/4" around the stripe itself.
2) take stripes out to car, lay them where they should go.
3) tape in place. put dash marks on the tape, going onto the paper wrapping of the stripes, to mark the proper location of the stripes.
4) remove stripes, but leave the tape with the marks
5) clean the place where the stripes go, and do a final rub down with some alcohol
6) mix a water/soap solution in a spray bottle: just a little bit of dish detergent or car wash soap, etc, mixed with a bottle of water. don't need too much soap.
7) 1- Spray solution on car, liberally. 2- Spray your hands/fingers. 3- remove the paper or plastic backing from the stripes, spray both sides of the stripes. lay stripes in place
8) with the stripes in place, get your squeegee and begin working the water and air out from under the stripe. Start from the CENTER and work your way out to the edges. keep the outside surface wet while working, so keep the spray bottle handy
9) heat helps with stubborn air pockets and helping the adhesive stick to the car. If using a heat gun, do not leave on any spot for long at all, they can damage the vinyl, blow dryers don't get as hot so they pose less of a threat. Squeegee out the air/water till the stripes lay down completely flat. Remove the plastic cover from the stripes
10) if you have any bubbles that you could not work out, leave them. give it a few days, and the air/water may work itself out. if after 2-3 days of being parked out in the sun the bubble is still there, get a small safety pin, and press through the hole, in the center. Using the squeegee work the air toward the hole. should lay flat now.
done... stand back and enjoy. Seems like a lot, but in reality, its a 15 minute job.
Old 08-18-2012, 10:31 AM
MavrikTA's Avatar
^^^ soapy water, my friend. Sounds like B.S. but it works great! Its how I applied mine back in the day.
Old 08-18-2012, 11:32 AM
awesome write up crimson bird!!! and yes soapy water is the trick
Quick Reply: took a shot with the blackbird stripes
