!wire mod (no cut) question
After searching and reading threads about the passenger !wire mod, I have a few questions. I was planning to buy the Weatherpack and/or Metri-Pack terminal tools to disassemble the connectors. One was a hollow tube-looking device with a screwdriver handle and the other looked like a thin, long blade, also with a screwdriver handle. Are these the only tools I need to disassemble/reassemble the connectors? If I go this route, do I still need to extend the wiring harnesses or is there already enough wire? Any suggestions, tips, part numbers, advice, etc. would be appreciated!
Originally Posted by CANNIBAL
Where are you getting the tools to remove the pins?
http://www.waytekwire.com/index.htm
The tools were cheap...one was $5 and the other $7...just look under tools, packard...
