Sponsored by: DashLynx
Old 05-13-2016, 02:58 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Specifications & General Maintenance
Print Wikipost
Best way to clean my engine/engine bay?
Old 11-07-2012, 01:12 AM
WicKeD SiXxX's Avatar
Default Best way to clean my engine/engine bay?
What is the best way to clean my engine and engine bay without ruining anything? I heard it is bad to just take a hose and start spraying under the hood. I dont want to mess up anything electrical. I have a 2000 V6 Camaro with a 3800 Series II V6.
Any help is appreciated. Thanks.
Old 11-07-2012, 02:15 AM
crimson_bird's Avatar
There's a thread in one of the stickys about cleaning the engine, but it might be in another section. I'll try to pull it up
*edit. here: https://ls1tech.com/forums/appearanc...ngine-bay.html
I pretty much followed that. But used Purple Power cleaner/degreaser. there's a bunch of talk about Simple Green that comes up in there, I chose to just stay away from it.
-hose down engine
-spray down with degreaser (let sit 5 minutes)
-hose down again to remove cleaner and some of that top dust/dirt layer
-spray again with degreaser (let sit a few minutes)
-break out the rags and cleaning brushes, and put in some time actually cleaning everything (the best you can)
-hose down again
-do more spot/focused cleaning as you see necessary (do it right the first time, and you wont have to do much to maintain the clean look in the future)
-after final hose down/ rinsing, start drying. I bought a leaf blower to help get in the tight spots as well.
-start up the car so the heat helps get things dry. And continue with your towels to finish drying everything
I used plastic bags to cover up certain plugs and things when I did my old v6 camaro, but I forget what exactly.
Be prepared, once you start cleaning it up in there, you'll want to do more to get it looking even better... $$$$
Old 11-07-2012, 11:09 AM
CamaroSS27's Avatar
Also to add try to get a brush helps a ton with tight stops!
Old 11-07-2012, 11:17 AM
BD1987's Avatar
I soak the engine in all purpose cleaner/degreaser...
Start the engine, and spray with a pressure washer...
Never had a single problem, just let it run with the hood closed after done spraying to evaporate any excess water
Old 11-07-2012, 11:19 AM
nintythreez28's Avatar
just to clairify to others please dont do this to an lt1 due to the opti. never get water on it.
Old 11-07-2012, 12:13 PM
Thanks guys!
Old 11-07-2012, 10:05 PM
ldyzluvdis06's Avatar
yup, i just spray it down with cleaner, then power wash it. i do this to 2 cars a day 5 days a week for the past couple of years and never have had an issue.
Quick Reply: Best way to clean my engine/engine bay?
