White Face Gauge Install
Old 04-14-2004, 02:43 PM
ChitownLS1's Avatar
Default White Face Gauge Install
I removed the needles when I installed the gauges and now they are a little off. How can I accurately reinstall them? I attached a pic of them with the car at operating temperature.
Old 04-14-2004, 03:48 PM
ddelallata's Avatar
mmmm.... the tach looks a little off. I don't know about the rest. remove the needles carefully so that you don't damage the finish of the new gauge face and with the car at normal temp and with the clear cover off reposition the needles were you most accurately feel they should be. There is no easy way around this kind of problem IMO.
Old 04-14-2004, 05:40 PM
BADFNZ-383's Avatar
i took mine off too, i just sent the cluster out to be recalibrated. i think it was like 100 bucks
Old 04-14-2004, 06:21 PM
ChitownLS1's Avatar
Where did you send it? Mine are just a little off, I'll try to reposition them while the car is warm, I have a pic of the stock gauges to reference.
Old 04-14-2004, 09:48 PM
BADFNZ-383's Avatar
its a place called model electronics. the main warehouse is in new york, which is where my cluster was sent. but mostly any speedo, or tach shop would be able to help you out
Old 04-14-2004, 10:52 PM
Eastern Bowtie's Avatar
What are they recalibrating?
Your suppose to remember where the normal operating positions are and then put the needles back on with the car on, and warm. It's like the first and last step in the instuctions.
Old 04-15-2004, 02:15 AM
BADz2ATE's Avatar
turn the ignition on and make a template of the needles and their positions. then shut it off diss assemble everything apply the gauges, and them turn the ignition back on and apply the needles to where they need to be according to your drawing. no easy way around your predicament, to be 100% accurate you will need a recalibration, other than that just guesstimate.
Mike
Old 04-15-2004, 09:45 AM
XtinctHawk02's Avatar
Why did you take the needles off?
I didn't think you had to do that...
Old 04-15-2004, 11:25 AM
Stew w/92&00's Avatar
some guages replace the whole backing,the Macewen overlays just "overlay"the stock backing.....
Old 04-15-2004, 11:43 AM
IntenseSS's Avatar
you were'nt supose to take the neddles off with those gauge overlays.....Those look like the ones from www.dynoproauto.com .....I just order those and the guy on the phone said you don't need to take the neddles of ...Just put the neddles at a 12 o, clock postion and slip the overlays over them.......
Old 04-15-2004, 06:50 PM
ChitownLS1's Avatar
Already figured that one out.
They are fine now, after taking them off and putting them on about 40 times. They are now set in the correct position.
Quick Reply: White Face Gauge Install
