Serious issues removing factory badges.
Heated them up and they peeled right off. Now, I can't get off the residue. I've used the 3m and turtle Wax adhesive remover, brake cleaner, wd40, nothing works. It also looks like the emblem pulled little hunks out of my fender.. . Any advice will be appreciated.
If you're saying the emblems pulled hunks of your fender off, then what advice are you looking for? I'd think the answer is pretty obvious... take it to a body and get it repainted if you're not capable of doing that kind of work. If the removed hunks are that serious, you'll be better off just purchasing a used fender since they're pretty cheap.
Its also possible that the Previous owner had the car painted and they didnt properly remove the adhesive before painting over it and it is locked in for good until sanded down and repainted.
