A4 shift knob swaps
Old 01-21-2013, 02:33 PM
88gtman's Avatar
Default A4 shift **** swaps
Well as many of you know unless you buy a special adapter there are not many options for the A4 shift *****. Well today I went out browsing the pick-a-parts for a stock t-handle shifter since mine is missing the actual button cap. I found a lot of early 4th gens, but sadly the shift ***** were either gone or destroyed. So I decided to browse around some more. I started to notice that a lot of the other GM cars had shifters that use the same style clip system as the A4 4th gens. Needless to say when all was said and done I picked up 3 shift ***** for a total of 7 dollars. All work fine and each looks very different from stock. I figure I may just swap'em around as I get bored with each one. Here is a pic showing how each one looks. There were some other *****, but nothing I thoughy might look good. I was wondering if anyone else has done a swap like this? I ideas of some other shift ***** that may look good from other GM vehicles that use the little clip to hold them in?
Old 01-21-2013, 03:00 PM
Ls1CamaroGuy87's Avatar
Leather wrapped Camaro was always my favorite. that was the first thing i changed in my Firebird... took it right out of my totaled Camaro
Old 01-21-2013, 05:50 PM
Furious1's Avatar
I picked up the adapter and put a pool ball shift **** on that matches the car.
Old 01-21-2013, 06:10 PM
lemons12's Avatar
I have a shortened stick and adapter.. Not sure what ball I'm going to run, will also have a boot from a Grand Am.
Doesn't the Trail Blazer handle also work?
Old 01-21-2013, 06:26 PM
Sail Hatan's Avatar
I shortened mine up, and used the adapter. I feel like nothing looks quite as good.
Old 01-21-2013, 06:41 PM
88gtman's Avatar
All GM shift handles will work ad long as they are the kind that use the little clip in the middle.
Old 01-22-2013, 06:30 AM
Latch's Avatar
Corvette ***** work as well, I've got one off a C5 and also got a boot from a Grand Am. It was worth it to get rid of those cheesy little plastic sliders.
Old 01-22-2013, 06:34 AM
Chaos07's Avatar
Trailblazer Ss handle. I have it on mine it looks pretty good
Old 01-22-2013, 08:18 AM
Copy & Paste Moderator
VIP1's Avatar
I have a Trailblazer SS handle in my Formula too.
I don't have a pic of min installed, but here is babbage1109's car:
Old 01-22-2013, 09:59 AM
88gtman's Avatar
So the TBSS handle uses the clip as well to hold it on?
Old 01-22-2013, 11:47 AM
PUNISHER TA's Avatar
I've got to figure something out for my new bird. I guess Ill look for these adapters...
but I really don't like how high it is, its unnatural for me, so i need to cut it as well.
As a note, before logging in, ***** was censored to *****... made me chuckle.
Old 01-22-2013, 11:49 AM
Chaos07's Avatar
my SS handle had a torx screw holding it in place no clip. I didnt use the leather boot on mine just needed the handle
Old 01-22-2013, 11:56 AM
babbage1109's Avatar
When I did mine I cut the clip part off and shortened the white part to fit. If you don't it sits too tall in my opinion. You don't have to. I just liked mine lower.
Old 01-22-2013, 08:31 PM
88gtman's Avatar
Anyone else swapped any good looking shift ***** into the A4?
Old 01-22-2013, 09:21 PM
VIP1's Avatar
No. It uses a torx screw for a friction fit.
Also, there is a tab on the inside of the handle's shaft that gets in the way of lowering it into position. I trimmed it out with a chisel. It'll make sense if you try to install it unmodified (since the handle will "bottom-out" too high to work).
Old 01-23-2013, 07:02 AM
JDEP162's Avatar
just fwiw, i bought the adapter, and put a B&M black T-handle in, and its nice. total cost bout 40 bucks. il grab a pic later and put up...
also, i have the scangauge too, and mounted above rearview mirror, got tired of it floating in that spot.
Quick Reply: A4 shift knob swaps
