Sponsored by: DashLynx
3m headlight restorer kit review
Old 01-23-2013, 03:53 AM
dhctss's Avatar
Default 3m headlight restorer kit review
I bought the 3m headlight restorer. The one you use a drill. I started kind of late this afternoon. Very brisk ok today her in Ct. Anyway I did all the steps fairly quick. Need to really take your time. It came out 50 percent better. I will do it again tomorow and take my time and I hope it will be almost 100 percent. I noticed especially when it rains at night it is hard to see. It should be good to go. I used the drill and then sanded the edged by hand. It is a pain around the little nipples. Why did chevy need to put those there
Old 01-23-2013, 08:59 AM
ncfastls1's Avatar
I've used it on two cars, a 98 Ford contour and a 99 Nissan altima. Worked great on both. Those nipples are a pain though, also make sure you tape off everything very well. I don't care how steady you think your hands are, you will scuff paint at some point lol.
Old 01-23-2013, 09:31 AM
silverWS.6's Avatar
Can't you grind off the little nipples and sand it smooth? You can do that prior to using the kit so it'll smooth it up better. I've been using the rain-x kit on my truck but it doesnt last very long, I have to redo about every 3 months.
Old 01-23-2013, 10:35 AM
Blownbayou's Avatar
I usually take 30-45 minutes a light and they come out great
Old 01-23-2013, 01:12 PM
9WhiteCamaro9's Avatar
If I were to do mine again, I think I'm gonna cut the "nipples" off to make it that much easier to work the headlight but when I did mine, I think I used the Mother's brand Headlight Restore and they came out real good but I didn't spend as much time as I needed to with them but maybe next time I'll take my time on them.
Old 01-23-2013, 01:22 PM
TORK?'s Avatar
As far as scratching paint, it only takes 2 minutes to take the hole headlight assembly off the car.
What grit sandpapers does the kit come with? I did mine with some paper I had lying around and finished it off with some Plastix polish I had. Cost maybe $3 and same end result.
Old 01-23-2013, 02:31 PM
dhctss's Avatar
Not sure if its actual grit but they call first step p500 ,p800 p3000 in that order. I did with lights on
Old 01-23-2013, 02:42 PM
TyCZ28's Avatar
i personally dont like the 3m or any ther restore kit for that matter... they are all wastes of money because after a fw months the lights end up looking like they did before.. the only real way to fix them is to wetsand till they oxodized part is off and the lights are smooth... then clear coat them (automotive clear works best)
Old 01-23-2013, 02:54 PM
gtfodave's Avatar
I sanded my gto lights with 800-1000-2000-2500 and then buffed them with a wool pad and rubbing coumpound. My headlights were ruined before I started since previous owner tried to smoke them but them came out great at the end
Old 01-23-2013, 06:32 PM
dhctss's Avatar
I wasnt paying attenion to time and it was like 400 when I started. worked on to 5 and will spend one more time doing steps when warmer. It looks way better. I will post pics when Im done.
Old 01-23-2013, 09:36 PM
mjs1012's Avatar
heres how mine came out after i wet sanded with 600,800,1500, then buffed them and used a sealer. they were almost yellow and even with my hids it was hard to see at night
Old 01-23-2013, 10:00 PM
Daniel Richards's Avatar
the sanding pads on the drill are a real pain in the *** to use, I have used the 3M kit before aswell. I have also used this kit that walmart carries that is a silver bag (don't remember the brand) and it comes with 2 different grit sandpapers and unlike buffing it out at the end like you do with the cream in the 3M kit it has a like clear acrylic liquid stuff that you wipe across the lense, you have to be very careful wiping it to apply even pressure so you don't get streaks and if done right gives a GREAT finish.
Now i'm glad to be in a firebird because all I have to do is buy new headlights.
Old 01-24-2013, 08:49 PM
The Guz's Avatar
I have used this kit as well. It's an ok kit. The sylvania is a much better kit. I used the sylvania kit on my dad's 02 headlights. I would definitely go with that kit over any other kit.
Old 01-24-2013, 10:49 PM
LilJayV10's Avatar
The reason you have to go back and do the lights again in 3 months isn't the kits fault. It's because when you restore the the head light lenses you are removing all of the UV protectant which causes the headlights to fail faster.
Whenever you restore your headlights you need to apply some sort of protectant rather it be a wax or a sealant designed specifically for headlights.
Old 01-25-2013, 09:15 AM
LOHRTBT's Avatar
The UV protectant is actually what is failing and yellowing.
Quick Reply: 3m headlight restorer kit review
