Sponsored by: DashLynx
Proper lubricant for a Clay bar?
Old 04-21-2004, 09:53 AM
LSX Mechanic
Damian's Avatar
Default Proper lubricant for a Clay bar?
I've ran out of the stuff my Clay magic bar came with. What is everyone using to lubricate while using the bar? TIA
Old 04-21-2004, 09:58 AM
FasterThanU's Avatar
I use my spray detailer...works great
Old 04-21-2004, 09:59 AM
OWENMUSTANG's Avatar
Same
Old 04-21-2004, 10:16 AM
99MONGOOSE's Avatar
If you don't have spray wax you can take an empty spray bottle and put a little carwash soap in it with some water and shake it up. This will give you a slick lubricant for your clay.
Old 04-21-2004, 11:07 AM
Copy & Paste Moderator
VIP1's Avatar
I think you can use the stuff that comes with the Mother's clay bar. (Its safe for the Mothers claybar so it should it should be safe for the ClayMagic claybar) I think its called "Quick Detailer".
--VIP1
Old 04-21-2004, 11:19 AM
30th TA 0219's Avatar
Quick Detailer is a Meguire's product
Old 04-21-2004, 11:31 AM
KCFormula's Avatar
I go to the power wash and use the pre-soak they have.
Old 04-21-2004, 11:43 AM
All i have ever seen used here in mi for pre soak is water
Old 04-21-2004, 07:06 PM
DóòD's Avatar
I use a lil bit of Zaino Wash with water in a spray bottle...
Old 04-21-2004, 08:34 PM
Chop-Foo Director
PendragonZ's Avatar
I just bought the mothers kit tonight. Used the spray detailer it
came with. I'm sure any spray detailer will be good. I tried my
first attempt at using the clay bar tonight. Anyone got some
quick tips for claying? How long should I rub a particular area?
BTW, I did the !pinstripe mod tonight as well. Then put on a fresh
coat of colorx and nxt tech wax. I'll try to get some pics tomorrow
if it doesn't rain or if there isn't an inch of pollen on the car
Old 04-21-2004, 09:08 PM
ddelallata's Avatar
if you want to get rid of the wax as well, use dishwashing fluid.... if not just use regular car wash soap.
Old 04-21-2004, 09:37 PM
minivette's Avatar
Rub it till it's smooth. You can tell.
Old 04-21-2004, 10:07 PM
VIP1's Avatar
Well, then... its got a similar name and its in a red bottle.
...feal and hear.
--VIP1
Old 04-27-2004, 10:32 PM
2002yroneformula's Avatar
I think the Mother's product is called Showtime. Might be mistaken but just throwing my $.02 in.
Old 04-27-2004, 11:42 PM
Brandon Boomhauer's Avatar
I use Meguiars #34 final inspection, its like 7 bucks for 16oz or 21 for a gallon around here.
Btw to see if the surface is smooth, put your hand in a sandwitch bag and rub over the surface, you will feel all the stuff you can't with a naked hand, or hear with the bar.
Old 04-27-2004, 11:49 PM
Quick 99's Avatar
I used my ziano car wash as lubricant, turned out excellent!
Quick Reply: Proper lubricant for a Clay bar?
