no HAVC and cluster light
so i did the led conversion on my car.everything went smooth and worked perfect till i decided to install led strip in the floor well..after installing them my HAVC,and cluster lights stop working..i tapped them into the mirror/map wires..they work perfect.but after i installed them the HAVC AND CLUSTER light went out.also tail lights went out replaced the fuse on those they're working.i checked all the fuses the DIMMER(5a) fuse was blow replaced tried again and saw smoke from the dimmer switch.replace those 3 times already.it did the same thing 3 times.blew a fuse and burned up the dimmer switch.i checked all my wire for short or loose wire,couldn't find anything wrong.somebody please help me out.
You may consider rewiring to another source. i feel like those LED's need a higher amp load. you need to consider a higher amp fuse as a start. if that doesnt work youll need to rewire to a better source. If it was my call i would run from the fuse box. there is accessory, ignition, and battery sources. I ran a wire for my gauges from the ignition. those are a 15amp source, id run a 14g wire and T-tap a lead for your LED's.
