Overlays
Overlays
for the bird and the doors and the headlight....and wherever else...whats the best way to apply the stickers...
how should you prep the area...and how would you prvent it from sticking on the car if you made a mistake?
step by step instructions would be GREAT
prep the surface with rubbing alcohol, then just get a spray bottle with water and some soap in it. Then just spray the area that the sticker is going to be placed on, then adjust the sticker till you get it where you want it, try to get the water out of the back of the sticker as much as possable. I use a credit card to press the sticker down and work from the middle out, this will press the water out from behind the sticker. then let it dry when it is dry the sticker will be fine.
Copy & Paste Moderator
Originally Posted by 01 Red WS6
some people are just trying to make this harder than it is for ya, just use soap and water and you will be fine
--VIP1
