Custom flip iphone stand ideas
Im trying to create a custom iphone stand, out of the ashtray lid in the center console. i would have to make the ashtray lid open about 130*s
Pretty much from this...
To this...
I would just run the iphone wire from the headunit, under the center console, around the shift boot, and probably clip it under the ahstray lid.
Anyone know the best way to do this? I was thinking about spot putty, but im opened to any suggestions or ideas.
To this...
I have been looking into doing this as well. My thoughts are to get an iphone docking unit and mold it into the ash tray area. If you mount it low enough you should still have room to close the lid. The docking units have the 30 pin connector out the back so if you run your wire from the head unit under the console you can then just plug it into the back of this unit. Where I am running into problems is how to mold the unit in and be strong enough so that it doesn't eventually crack from pushing the phone down onto the connector.
This is the unit I got
It is also available with the iphone 5 connector
The only problem with this unit is the phone cannot be in a case. You need a dock extender if you use a case and from what I have found adding the extender makes the phone unstable.
This had been done and well documented on here a few times. Here's what I made for all of my iPhones...
https://ls1tech.com/forums/stereo-el...camaro-bird.html
Now I have a 5 and all I needed was the "30 pin to lightning" connector and my phone is fine. Not unstable or anything. It charges and plays everything.
This is kinda similar to what im trying to do, but instead of a slot, i want to make use of the ashtray lid instead.
https://ls1tech.com/forums/paint-bod...dio-bezel.html
