what is a good wash mit?
What are you using to dry? I find that more important than the mitt if you have a good soap and clean water. Whats the point in a good mitt if you are using a beach towel to dry?
Don't use a chamois to dry, they have no nap so if anything falls on the paint or didn't get cleaned off prior to drying it will be dragged all across the paint. A good drying towel would be a Cobra Guzzler HD waffle weave towel or a nice size Waffle Weave Microfiber Towel.
Also never use dawn soap unless your trying to strip off wax, because that's what it will do. Use the meguiars soap or whatever brand you prefer. NEVER use dish soap to wash a car unless you are doing it prior to applying a new coat of wax to strip the surface
Get a foam cannon from whatever online detailer supplier you fancy, and then get a decent mitt from that same supplier or a local store. The cannon, or more accurately the foam it produces, will do most of the hard cleaning for you. Any mitt is going to cause swirls if you don't get the paint as clean as possible prior to running anything over it.
1. A foam gun is more effective than a foam cannon. Yes a foam cannon looks cool but the foam sits on the car and doesn't run off pulling the dirt with it. The reason is a foam cannon by design uses less water than a foam gun.
2. Regardless if you are using a foam gun or cannon it doesn't do the "hard cleaning" for you. The only way to get all the dirt off is by agitation via some sort of wash mitt. You could spend an hour foaming your car but it's still going to be dirty. Some clear coats are more scratch resistant than others. If you have ever washed a black car with soft paint you will see what I'm talking about.
3. A good wash mitt is not only soft it holds the dirt inside the fibers to keep them from staying on the surface giving the dirt the chance to marr/scratch the finish.
4. Any time you touch your paint you run the risk of inducing marring, scratches/swirls so the softest mitt or MF towel you can use is best. If this wasn't the case the cheap MF towels you can buy at Auto Zone would be good enough. The fact is a cheap MF towel, drying towel or wash mitt can and will marr the paint.
5. The main benefit of using a foam gun is it adds extra lubrication to the paint instead of just water. If you are washing a really dirty panel its a good idea to use the foam gun in front of your wash mitt as you go to help add even more extra lubrication.
Is just using a good wash mitt enough to prevent marring? No. Good wash techniqes, two bucket method is a must and a foam gun all play an important part.
I use the foam gun from Autogeek.net and i have a boar's hair brush along with a 5 gallon bucket and the grit guard. autogeek.net has all the good brands. I use all Pinnacle products on my Black SS and my charcoal grey GMC Sierra.
